Gear indicator - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Gear indicator (/showthread.php?tid=69383) |
Gear indicator - rok.bezan - 25-06-14 Hy They told me to write here, so you could help me. I have a quastion: Is it posible (if it is how to do it and witch is the best?) to mount a gear indicator to my Yamaha, i have a FZS 600 2003.? Sory for any mistakes in my English Re: Gear indicator - kevinuk1 - 25-06-14 Hi this product works on our bike http://www.healtech-electronics.com/products/gpx/ You can purchase it from here http://www.bikersdiscountstore.co.uk/gear-indicators-shift-rev-lights-tre-devices/healtech-electronics/gipro-x-type-gear-indicator-shift-light-pd-42.php The one you want is GPX-Y01 Not got one myself but considering buying one, if you get one let me know Cheers Kevin Re: Gear indicator - rok.bezan - 25-06-14 Tnx for help, i will se about that, as i looked, the Fzs 2003 doesnt have much of electronics.... I will se how to instal it and tel about it.. Im a engenir of Elektrotehnics so that scouldn't be a problem to install XD Re: Gear indicator - Millietant - 26-06-14 What I don't get is the makers have a retail price of 89 euro's (£71.50) yet the "Bikers Discount Store" want £99.99 for it. Some 'effin discount that - even with VAT added on top of the Euro price. Looks like we're gettin ripped off. Re: Gear indicator - midden - 26-06-14 Theyre that expensive! Surely there can't be to much to them. Perhaps an electroncs engineer should investigate and make one for less. A lot less Re: Gear indicator - imax - 26-06-14 For a little bit more, you could join the group buy for the multi gauge, which looks a much neater solution and the electronics work doesn't sound like it would be an issue. http://foc-u.co.uk/index.php/topic,13218.0.html Re: Gear indicator - midden - 26-06-14 http://www.angelfire.com/wa3/r.miklos/shiftindicator/gearindicator.htm Re: Gear indicator - Fazerider - 26-06-14 (26-06-14, 09:29 AM)midden link Wrote: http://www.angelfire.com/wa3/r.miklos/shiftindicator/gearindicator.htmThe ZX12 has the advantage of a rotary switch on the selector drum, the FZS600 only has a neutral switch. To work out what gear you're in you'd need to calculate it from the ratio of engine revs to pulse rate from the speedo sender... presumably that's how the Healtech unit works, but I guess it'll be confused when the clutch is pulled. Re: Gear indicator - Ruby Racing - 26-06-14 (26-06-14, 09:04 AM)imax link Wrote: For a little bit more, you could join the group buy for the multi gauge, which looks a much neater solution and the electronics work doesn't sound like it would be an issue. If I was in the market for one (I'm not), that's definitely the one I'd go for. I have to agree it's a VERY neat design and fits in seamlessly with the OE clocks. Much better than tagging on a separate gear indicator that doesn't match anything. Re: Gear indicator - rok.bezan - 27-06-14 I agree, the multi is much nicer. But the schematics look awesome but i think it would work only on newer bikes... :/ |
