12v Phone Charger Socket - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: 12v Phone Charger Socket (/showthread.php?tid=69242) |
12v Phone Charger Socket - Peasy - 15-06-14 Evening all, I wondered if anyone could recommend a 12v socket for fitting to my bike that I can charge my phone whilst riding. Would be under the seat rather than exposed anywhere. There seems to be loads of different ones available and I am sure they're all similar but would be good to get a recommendation or 2 Thanks Lewis Re: 12v Phone Charger Socket - nsr500v4 - 16-06-14 https://www.buybits.com/Product/9803/Ultimate-Addons-Straight-Mini-Usb-Direct-To-Battery-Hard-Wire-Motorcycle-Charging-Cable-sku-9803.aspxhttps://www.buybits.com/Product/9803/Ultimate-Addons-Straight-Mini-Usb-Direct-To-Battery-Hard-Wire-Motorcycle-Charging-Cable-sku-9803.aspx I use this, waterproof, straight to battery and just switch it off under the seat when it's not being used, loads of different cables available too so should suit all the gadgets... Re: 12v Phone Charger Socket - hightower - 16-06-14 I just bought this: http://www.ebay.co.uk/itm/Bike-It-12V-Waterproof-Motorcycle-Cigarette-Lighter-Power-Socket-/141282150114?pt=UK_Motorcycle_Parts&hash=item20e51286e2 Haven't fitted it yet, but looks the job. Planning to fit under seat although cable should be long enough to go to bars should I change my mind. Re: 12v Phone Charger Socket - PaulSmith - 18-06-14 They are all pretty much the same but make sure you get one suitable for a boat or other exposed use. Probably the only difference will be that the cap and or case will be rubber instead of plastic to make it weather proof. Although you can go straight to the battery, I would strongly advise that you go via a relay on a switched circuit such a the side lights. Pat's site shows you the wiring needed. http://www.cartestsoftware.com/fz1/cigarettelightersocketinstallation.html It is not nearly as scary as it first looks as Pat had two or three other things wired into the same place. I did not like Pat's choice of location, and I didn't want it under the seat as for me that that meant too much faffing around to get to it, so I found that hanging it from the bar holding the front right fairing in place was the best solution for me. It is very hard to see unless you go looking for it, but it is easy to hand and obvious when I have left something plugged in and has the advantage of being very close to the bars for powering GPS etc. |
