Gear box - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZ6 / FZ6 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=77) +--- Thread: Gear box (/showthread.php?tid=69135) |
Gear box - AMW - 09-06-14 Well not a good day I have had a noise from the bike for a week or so seemed to be getting louder. So I had the bike shop check it out the findings not very good. Main gear box bearing gone (probably) to fix it £££££ (£800 ish labour and parts ) :'( Andrew Re: Gear box - johna6968 - 09-06-14 The temptation to put a good used motor in the bike rather than shell out for the repair would be all too much.. Re: Gear box - Dave48 - 10-06-14 (09-06-14, 07:23 PM)AMW link Wrote: Well not a good day I have had a noise from the bike for a week or so seemed to be getting louder. So I had the bike shop check it out the findings not very good. Main gear box bearing gone (probably) to fix it £££££ (£800 ish labour and parts ) :'(Time to speak to Deefer? Re: Gear box - AMW - 11-06-14 A replacement engine seems the better option (just a case of finding a good one). Andrew Re: Gear box - Exupnut - 11-06-14 Before u do ANYTHING speak to Deefer aka mark. What he doesn't know bout fazer6's u can write on back of a stamp. Re: Gear box - AMW - 15-06-14 Quote:Deefer aka mark I shall try and contact him. Andrew Re: Gear box - Deefer666 - 16-06-14 Did someone mention my name? Main bearing on an FZ6? If the output shaft bearing has gone, then it probably means that the chain has been run too tight by a previous owner... That's what normally kills them, you will be lucky if it hasn't taken the bearing on the other end of the shaft with it. Normally its about £300-400 all in Re: Gear box - ChristoT - 16-06-14 (16-06-14, 06:55 AM)Deefer666 link Wrote: Did someone mention my name? Invoked the God of Fazers, more like! :lol :lol :lol Re: Gear box - AMW - 16-06-14 Hi Deefer666 Thank you for the reply. Over tight chain could be the issue as I had to change the chain and sprocket not long after I bought it. It had a few stiff links causing a clicking as it went around not in great condition. Quote:Normally its about £300-400 all in If only I have had quotes of £800+ Andrew Re: Gear box - ChristoT - 16-06-14 Save yourself £400, stick it on a bike trailer, adn take it to Molesworth. Works out at 120 miles each way: a small price to have the God of Fazers breathe on it!
Re: Gear box - AMW - 17-06-14 Sounds like a plan if I can source a trailer. Andrew Re: Gear box - Deefer666 - 17-06-14 OK let me know Re: Gear box - AMW - 17-06-14 Thank you, it is about two hours from my house to you so not to bad. I am not able to do anything for a few weeks as I head to France on Friday for a mix of cave diving and visiting family over two weeks. Although she is looking sorry for her self so needs fixing as soon as possible. Andrew |
