Brake Hoses - A Question - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Brake Hoses - A Question (/showthread.php?tid=68955) |
Brake Hoses - A Question - N A Chess - 29-05-14 Hi Al Can anyone tell me the difference between the standard OEM front brake hoses and 'Full Length Race' ones? I have ordered the latter - they are £30 quid cheaper - but have no idea how they differ from standard. Perhaps I should have found out before buying :rolleyes Re: Brake Hoses - A Question - John Silva - 29-05-14 OEM are one hose from master cylinder to splitter then two hoses to callipers. 3 hoses in total. Race setup is two hoses from master cylinder straight to the callipers. 2 Hoses in total thus cheaper than OEM Simples
Re: Brake Hoses - A Question - SteveCardiff - 29-05-14 Race hoses use seperate lines from the master cylinder so if one gets damaged and leaks fluid you still have one working caliper. Re: Brake Hoses - A Question - fazersharp - 29-05-14 (29-05-14, 09:36 PM)SteveCardiff link Wrote: Race hoses use seperate lines from the master cylinder so if one gets damaged and leaks fluid you still have one working caliper.Think that might be wrong I have the two line system which has done away with the cross bar section under the fairing, its quite simple rearlly as all it is - is a double banjo bolt at the master cylinder, so although it is two lines they are connected at the cylinder so wont help if one is damaged Re: Brake Hoses - A Question - richfzs - 29-05-14 Agree with fazersharp. You would only get the one-working-caliper, if the lines were fitted with non-return valves, which obviously they can't be! So if one line is damaged, all the pressure will be released through the damaged point. No brakes is no brakes. Re: Brake Hoses - A Question - His Dudeness - 30-05-14 you could loosen a bleed nipple and test the theory Re: Brake Hoses - A Question - SteveCardiff - 30-05-14 I stand corrected, of course one wouldn't work,that's the Stella talking ![]() Re: Brake Hoses - A Question - SteveCardiff - 30-05-14 ......a very very early stella :rollin Re: Brake Hoses - A Question - N A Chess - 30-05-14 Thanks for all your responses - Stella ones included. :lol Hopefully should be a doddle to fit. Re: Brake Hoses - A Question - fazersharp - 30-05-14 Does stella work in the brake lines also then Cause ive been drinking brake fluid and its dosent work like stella Re: Brake Hoses - A Question - His Dudeness - 30-05-14 (30-05-14, 08:43 PM)fazersharp link Wrote: Does stella work in the brake lines also then It's a liquid so it's not compressible so it would work! Re: Brake Hoses - A Question - fazersharp - 30-05-14 (30-05-14, 09:30 PM)His Dudeness link Wrote: [quote author=fazersharp link=topic=13351.msg150942#msg150942 date=1401478982] It's a liquid so it's not compressible so it would work! [/quote] I seem to be able to compress quite a lot of it down my neck Re: Brake Hoses - A Question - His Dudeness - 30-05-14 (30-05-14, 09:59 PM)fazersharp link Wrote: [quote author=His Dudeness link=topic=13351.msg150955#msg150955 date=1401481846] It's a liquid so it's not compressible so it would work! [/quote] I seem to be able to compress quite a lot of it down my neck [/quote] :lol I like the odd beverage myself :lol Re: Brake Hoses - A Question - richfzs - 31-05-14 (30-05-14, 09:30 PM)His Dudeness link Wrote: [quote author=fazersharp link=topic=13351.msg150942#msg150942 date=1401478982] It's a liquid so it's not compressible so it would work! [/quote] It's more gas than liquid. It also looks like piss, tastes like piss... Mind you I've stopped pretty fucking quickly when I've needed a piss, so maybe it would work... Re: Brake Hoses - A Question - His Dudeness - 31-05-14 he could drink the stella and then piss in the master cylinder to remove the gas :lol Re: Brake Hoses - A Question - fazersharp - 31-05-14 (31-05-14, 12:29 AM)His Dudeness link Wrote: he could drink the stella and then piss in the master cylinder to remove the gas :lolThat would just change great brakes into pissy ones ! Re: Brake Hoses - A Question - SteveCardiff - 01-06-14 Bring your bike to me, i'll fuck up your brakes but i'll make your horn louder :lol |
