Starter motor spark - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Starter motor spark (/showthread.php?tid=68920) |
Starter motor spark - hightower - 27-05-14 This is for my KZ hence general forum. I've just rebuilt the starter, and when I plugged it back in to the battery I got a spark and not much else. I'm sure I've assembled it correctly, but obviously not. What would cause this? Sounds like a short somewhere but not sure where Re: Starter motor spark - Kosmic Kartman - 27-05-14 Would that be a Kawasaki KZ650? Re: Starter motor spark - hightower - 28-05-14 KZ 440 Re: Starter motor spark - His Dudeness - 28-05-14 Did it turn freely by hand after you put it back together? Did you test it in the bike or on a table? Re: Starter motor spark - hightower - 29-05-14 It didn't really turn freely by hand. I tested with a battery pack on the table, then on bike too Re: Starter motor spark - His Dudeness - 29-05-14 Any that I've had didn't quite spin freely because of the brushes but you could easily turn them by hand with a bit of resistance. It shouldn't be hard to turn if it is then it's probably stuck and you should take it apart again. You could have blown a fuse too when you tried it on the bike so check them too Re: Starter motor spark - hightower - 29-05-14 I defo blew a fuse on the battery pack. Not sure about bike yet |
