Cannot remove Oil filter - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Cannot remove Oil filter (/showthread.php?tid=68869) |
Cannot remove Oil filter - St.eve - 23-05-14 Hi Guys I am at my wits end cannot remove oil filter tried by hand at first then tried a strap then as a last resort did the screwdriver thing through the filter still no joy went to my local dealer got a cup that fits over filter the proper tool for the job but because I had damaged the filter trying the screwdriver idea the cup now slips round not sure what to try next the filter was only fitted last September by my local dealer just do not know what to do next. Can you help. Steve Just thought its not an opposite thread is it. I am pleased to tell you guys I have now removed the Oil Filter using a Large Hammer and a Screwdriver thanks for all your tips . Re: Cannot remove Oil filter - Fazerider - 23-05-14 No, it's a conventional thread. I always use an old wood chisel (or an old screwdriver that's been sharpened), just position the blade on the rim of the filter aiming at an angle so that tapping with a hammer partly makes it dig in to the metal slightly and partly forces it round in the desired direction. Re: Cannot remove Oil filter - karlo - 23-05-14 I used a pair of 16" water pump pliers on a mates when he had it as he couldn't get the filter of his. Re: Cannot remove Oil filter - keithfzs1000 - 23-05-14 http://www.ebay.co.uk/itm/ADJUSTABLE-12-OIL-FILTER-PLIER-PLIERS-WRENCH-HAND-REMOVAL-TOOL-/111292501299?pt=UK_Hand_Tools_Equipment&hash=item19e98ccd33 get pair of these Re: Cannot remove Oil filter - St.eve - 23-05-14 (23-05-14, 05:19 PM)keithfzs1000 link Wrote: http://www.ebay.co.uk/itm/ADJUSTABLE-12-OIL-FILTER-PLIER-PLIERS-WRENCH-HAND-REMOVAL-TOOL-/111292501299?pt=UK_Hand_Tools_Equipment&hash=item19e98ccd33 Just ordered those Thanks. Re: Cannot remove Oil filter - Lawrence - 23-05-14 Rubber gloves always to the job for me. Re: Cannot remove Oil filter - robby boy - 23-05-14 I'm with Fazerrider on this one, sharp screwdriver or chisel on the rim near the engine, few gentle taps in the right direction and it should come off. Re: Cannot remove Oil filter - dazza - 23-05-14 I had this problem once, only ever use K&N filters now with a nut welded on the end for easy removal with a socket and extension bar. Re: Cannot remove Oil filter - darrsi - 24-05-14 When you eventually get the filter off, smear a bit of oil on the rubber seal of the new one and just nip it up, you don't need to ever go mad with it. If it ever does drip, do it up a tad tighter, but it doesn't need tightening up a lot at all. Re: Cannot remove Oil filter - SteveCardiff - 24-05-14 A smear of oil, then tighten by hand is all it needs. I've got several tools to remove oil filters but never need em on a filter that i've personally fitted. A handy tip is to loosen the filter when the engines cold so you don't burn yourself on the exhausts. Once you get it loose, re-tighten gently and then warm the engine before draining the oil and removing the filter. |
