Rear shock - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Rear shock (/showthread.php?tid=68761) |
Rear shock - nsr500v4 - 17-05-14 Can anyone accurately measure the width of the top of the standard shock so i can get washers made of before fitting the BMW S1000 shock please? Re: Rear shock - bludclot - 19-05-14 34.92mm to 35.02mm depending upon which angle i measure across the faces of the bush. it's probably worn unevenly in use. Re: Rear shock - nsr500v4 - 19-05-14 Cheers Bludclot, i will get the new washers made up now
Re: Rear shock - unfazed - 19-05-14 I made up two washers 2.65 mm thick 12mm hole in centre Re: Rear shock - bludclot - 19-05-14 i am in need of 2 appropriate washers, any chance one of you can make up / obtain a pair for me please? funds can change hands in return obviously. Re: Rear shock - mickvp - 19-05-14 i should be able to make up a couple of sets in work next week if you dont mind waiting bludclot? I wont charge you anything, wont cost me much to pop a pair in an envelope. Anyone got any idea what the od of the washer should be roughly? just dont want them to have too-big a diameter obviously, and im too lazy to strip out my shock to measure it :lol Re: Rear shock - red98 - 19-05-14 I'll be taking my shock off tomorrow evening.i'll post the sizes then...anything else while ive got it off ? Re: Rear shock - mickvp - 19-05-14 12mm ID, 2.65mm width, just need OD red ![]() unless of course you guys want a fancy design or surface finish :lol Re: Rear shock - red98 - 19-05-14 Ok...will post tomorrow
Re: Rear shock - red98 - 19-05-14 Shocks off.do you want the od of the washer on the top mount ? Re: Rear shock - red98 - 19-05-14 or the metal sleeve that passes through the top of the shock.... Re: Rear shock - unfazed - 19-05-14 25mm OD will be fine Re: Rear shock - mickvp - 19-05-14 aye. anywhere between 23-25mm will be ok then ![]() Cheers Red, your a star mate. Re: Rear shock - red98 - 19-05-14 No probs for me, needed to replace the swingarm bearings so your timing was spot on.......this is why the forum is so good.....everyone helping one another....
