Modified front end - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Modified front end (/showthread.php?tid=68680) |
Modified front end - Par6 - 11-05-14 Naked ! Re: Modified front end - emjaydee - 12-05-14 Which headlight bracket did you use? Any chance of a photo of the front of the bike? Thanks Re: Modified front end - Super_Monkey - 12-05-14 and the side of the bike too, oh and Giz my bars back!! :rollin Re: Modified front end - Par6 - 12-05-14 The headlight brackets were from eBay £9.95. Re: Modified front end - emjaydee - 12-05-14 (12-05-14, 10:30 PM)Par6 link Wrote: The headlight brackets were from eBay £9.95.is it possible you could post the link, the brackets I see are too small. Re: Modified front end - Par6 - 13-05-14 To be honest the brackets are a little bit too short in their reach, if I find some longer ones I will be replacing them. I had to cut away a bit of the bowl on the headlight as it is right up against the ignition housing. Re: Modified front end - The Gentleman Biker - 16-05-14 I don't know if it helps but mine has XJR400 parts, (from the factory) the instrument panel and headlight including bracket I believe. Oh and I salute you going naked Sir. Re: Modified front end - emjaydee - 16-05-14 (16-05-14, 09:04 PM)The Gentleman Biker link Wrote: I don't know if it helps but mine has XJR400 parts, (from the factory) the instrument panel and headlight including bracket I believe.did the instrument panel fit straight on? any rewiring needed? Thanks Re: Modified front end - The Gentleman Biker - 16-05-14 (16-05-14, 09:23 PM)emjaydee link Wrote: [quote author=The Gentleman Biker link=topic=13075.msg148639#msg148639 date=1400270675]did the instrument panel fit straight on? any rewiring needed? Thanks [/quote] I don't know it is standard naked from the factory (JDM) Mine is a FZ400 so the XJR400 clocks probably wouldn't match up with the 600 fazer. But maybe the the XJR600 would? |
