135mm jack up kit, what ride height? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: 135mm jack up kit, what ride height? (/showthread.php?tid=68638) |
135mm jack up kit, what ride height? - mustardbufc - 09-05-14 What ride height difference would 135mm dog bones give me over standard? Re: 135mm jack up kit, what ride height? - fazerphil - 14-05-14 It depends on wot shock u got fitted. For a start or if u altered any anything else. R6 shock with 134mm dogs is near standard 130 mm dogs is better , on the mainstand the back wheel is 5 or 6 mm Off floor. Re: 135mm jack up kit, what ride height? - Camshaft - 14-05-14 I thought 130 for R6 shock was for stock ride height. They came with my R6 shock to "correct ride height" 126 dogs raises rear by 20mm giving your toes a little more cornering clearance at the cost of making the shock feel harder from my experience[size=78%] [/size] :nana Re: 135mm jack up kit, what ride height? - karlo - 14-05-14 (14-05-14, 09:26 AM)Camshaft link Wrote: I thought 130 for R6 shock was for stock ride height. They came with my R6 shock to "correct ride height" Your quite correct. 8) Std is approx 144mm iirc and I reckon for every 6mm will give approx 25mm difference. Re: 135mm jack up kit, what ride height? - fazerphil - 14-05-14 Dunno about that but centre to centre the dogs from both my fazers was 140 mm. only way to know for sure must be to measure from say axle to fixed point on frame say seat lock. With bike on mainstand remove dogs and move wheel until dog fixing points are 135mm, chock wheel in position Then remeasure the same fixed point on frame to axle. |
