Head gasket?? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Head gasket?? (/showthread.php?tid=68588) |
Head gasket?? - leviathanrising - 05-05-14 God damn it every time I seem to have fixed and run the bike something else seems to go wrong. Now when it gets warm it decides to blow white/blue smoke after about 3 minutes running on the idle with it blowing every sec or so. It smells like partially burnt petrol so I'm assuming it can't combust enough. My suspicions I think are confirmed given that I have a small patch of water where it seems to have leaked from the exhaust in a hairline crack (it also seems to steam from here when running). Confirmed? Re: Head gasket?? - humbucker88 - 10-05-14 Blue smoke is burning oil, white smoke is burning water. Pull the spark plugs to investigate symptoms, hopefully it's nothing bad. Re: Head gasket?? - red98 - 11-05-14 check the coolant in the header tank to see i its using any
