Whining sounds from front end once over 25mph - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Whining sounds from front end once over 25mph (/showthread.php?tid=68511) |
Whining sounds from front end once over 25mph - Arfa - 02-05-14 This last couple of days, I've noticed a whining, whistling sound from front end, once I get above 25-30mph ish. What do you reckon, wheel bearings? Crud in brakes? Front pads were new around Jan/Feb ish. New Speedo thingy was fitted then too, as old one broke. Front tyre was new about 2 months ago. If I lift front up, the wheel does seem to have some resistance when turned, as though it's catching/rubbing on something. When I turn slowly on a tight corner (out of sharp junction for instance) the front end does feel a bit notchy, although it's always felt like this as long as I remember. What do you reckon? Re: Whining sounds from front end once over 25mph - kebab19 - 02-05-14 Did you do all the work yourself or take it to someone? Has the noise been there since the remedial work? You may have a front brake piston playing up, tho not necessarily seized or even stuck, just not fully backing off. I find bluespots to be frustrating brakes, wonderful when working but a bit temperamental in that their performance is quick to go off. Also, long shot but you didn't have a Bridgestone BT-021 front tyre fitted ? Known for making howling noises via the front mudguard Re: Whining sounds from front end once over 25mph - Arfa - 02-05-14 Nah, garage did work. Work was done few months ago, noise just started in last day or two. Tyre is a Metz Z8. Did give bike a good wash earlier in week, wondering if I've dislodged some crud etc around brakes... Either way, sound like I'm gonna have to book it in for a check up. Re: Whining sounds from front end once over 25mph - noggythenog - 02-05-14 Catching on the mudguard maybe...have you checked all the mudguard bolts are nice & tight??? Re: Whining sounds from front end once over 25mph - mickvp - 02-05-14 any play in the wheel bearing? Re: Whining sounds from front end once over 25mph - Frosties - 02-05-14 (02-05-14, 11:16 AM)Arfa link Wrote: This last couple of days, I've noticed a whining, whistling sound from front end, once I get above 25-30mph ish. Have you tried asking the wife to shut her legs
Re: Whining sounds from front end once over 25mph - andybesy - 02-05-14 When my front wheel bearings went I first noticed as an occasional "clink" sound when changing speed or direction and handling generally sucking. I could well believe others have different symptoms and different noises. To checkout the bearings check for play in the wheel forward/back and side/side. Could still be bad even if no play, but if there is then you know you need bearings changed. That's probably a garage job but I think it was just an hour's labour plus parts. Binding brakes can make a whooshing noise but generally I've noticed it at speeds BELOW 25 mph or even when pushing it, as it's never been loud enough to hear at greater speeds. When you spin the wheel with a firm push, do you get 1/2 turn or more of travel before it stops? Spray some brake cleaner in there, try and get the crud off the pistons, they should be shiney. If need be pull off the caliper, drop out the pads and clean the pistons. Delboy's garage has good vids on this, or wouldn't be expensive to get done. Re: Whining sounds from front end once over 25mph - ade the blade - 02-05-14 (02-05-14, 01:29 PM)Frosties link Wrote: [quote author=Arfa link=topic=12905.msg145847#msg145847 date=1399025815] Have you tried asking the wife to shut her legs [/quote] sweeeeeeeeeet ! i thought perhaps a wolf was sat on the front fender merrily whilstling a tune or two ! :lol :lol Re: Whining sounds from front end once over 25mph - Rikki - 03-05-14 Unusual noises at 25-30mph+ could be the speedo drive. Did they put any grease in the speedo sensor unit when they changed the 'thingy' (I assume you mean the ring with the 2 lugs either side, also known as a rotor!)? Even a new one can make unusual grinding noises if not greased up. The heat/friction/vibration may also kill it, costing another £15 for a new one. Try taking the front wheel off & put some grease in there to see if that cures it. Having said this though, if you are experiencing handling issues it is probably not going to be the speedo drive. Re: Whining sounds from front end once over 25mph - Arfa - 03-05-14 Just back from garage. Took wheel off and had a good nose round. Reckoned there was no obvious issues with bearings, just gave everything a bit of a clean and greased up bearings and speedo as it was looking quite dry. No noise on ride home, so hopefully sorted! Yes, speedo thing is the speedo rotor, plastic ring with couple lugs on it. Garage said they'd seen a few Fazers with a similar issue. Either way, they only charged me a tenner, so canna moan really. |
