Brake light problem - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Brake light problem (/showthread.php?tid=68485) |
Brake light problem - bigfootpete - 30-04-14 Just wondering if anyone has any ideas about my brake lights not working: FZS1000, both headlights and tail lights function, but applying the hand brake or foot brake does not activate the second filament of the brake lights bulbs. Fuses are all ok, indicators also work fine, its just the brake lights. I checked the wiring where it connects from the master cylinder and that appears to be ok. Re: Brake light problem - BBROWN1664 - 30-04-14 is the bulb knackered? Re: Brake light problem - bigfootpete - 30-04-14 Nope, both bulbs are in perfect condition, filaments are intact. Re: Brake light problem - Mark YPVS - 30-04-14 Has the bulb been changed recently? if so is the new one fitted correctly , check the pin orientation as some are offset and some are straight :rolleyes Mark
Re: Brake light problem - bigfootpete - 30-04-14 No, they are the original bulbs (2003)
Re: Brake light problem - Dave48 - 30-04-14 Wiring connectors inside tail tidy? Any corrosion present? Earth ? Re: Brake light problem - bigfootpete - 30-04-14 I couldn't see the wiring, I might have to get right inside to check the wiring further. Re: Brake light problem - richfzs - 30-04-14 filament might look intact, but I've had bulbs look like that and still be knackered. Stick a new one in, ya tight foccer :lol Re: Brake light problem - bigfootpete - 03-05-14 Thanks Rich, I'll try that :-) Re: Brake light problem - bigfootpete - 04-05-14 New bulb - same problem. I took off the rear fairing today and checked all the wiring, couldn't see any cuts or bare wires or reason why the brake lights aren't working, also followed the wiring all the way through and even re-crimped the connections just bellow the master cylinder. I'm taking it in on Tuesday afternoon to see if the local shop can resolve the issue. Re: Brake light problem - richfzs - 04-05-14 :-( sorry pal, worth a shot though, easy stuff first Re: Brake light problem - dazza - 04-05-14 Check your brake light switches. I had the same problem. Front one was knackered rear needed adjusting. If it's the front switch don't buy cheap ones off ebay like I have. I've had two in less than a year and it's just gone again. |
