Timing question - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Timing question (/showthread.php?tid=68445) |
Timing question - humbucker88 - 27-04-14 I'm setting the timing on my camchain but I appear to be a tooth out on the exhaust cam. Can I remove the camshaft holders on just the exhaust camshaft, rotate it and tighten them down again without damage? Or do I need to undo both the exhaust and intake camshaft holders? Cheers Re: Timing question - unfazed - 27-04-14 After removing the tensioner, you will have to remove the inlet cam and then the lift the exhaust cam to give enough space to move the chain one tooth. :'( |
