Another question about the R6 shock upgrade - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Another question about the R6 shock upgrade (/showthread.php?tid=68416) |
Another question about the R6 shock upgrade - Super_Monkey - 26-04-14 OK so I bought the unit from our resident good egg Luke, but before I fit the unit I wondered if anyone has actually used a jack up kit WITH the R6 unit? I spoke to Luke but he's unsure if anyone has, so before I fit said unit I thought I'd ask the question on here, I'm over 6ft and my last Fazer had the jack up kit and it suited me well, but throw in the R6 shock into the equation and I'm unsure as to how the handling will be??? Re: Another question about the R6 shock upgrade - Camshaft - 26-04-14 Hi, I'm 6ft and fitted R6 shock with 126mm (130 for stock height with the R6) centres dog bones which gave a 20-22mm ride height measured from axle. I noticed the height first time I sat on it and it rides fine. Switching back to stock then the 126 I prefer the 126's. Raising the forks 8mm made a noticeable diff for faster steering, the diff rear height not so so noticeable to me. Re: Another question about the R6 shock upgrade - devilsyam - 26-04-14 I can swap them out for 126's if you don't like the stock Reason I don't push these as the r6 shock is much firmer Try it first then we can talk options Re: Another question about the R6 shock upgrade - Super_Monkey - 26-04-14 (26-04-14, 11:29 AM)Camshaft link Wrote: Hi, I'm 6ft and fitted R6 shock with 126mm (130 for stock height with the R6) centres dog bones which gave a 20-22mm ride height measured from axle. raising the forks 8mm as opposed to dropping them through the yokes??? So your happy with the standard height the R6 shock gives the Fazer?? Re: Another question about the R6 shock upgrade - Super_Monkey - 26-04-14 (26-04-14, 11:32 AM)devilsyam link Wrote: I can swap them out for 126's if you don't like the stock cheers Luke Re: Another question about the R6 shock upgrade - devilsyam - 26-04-14 camshaft is in aus so there will be satalite delay in replies lol Re: Another question about the R6 shock upgrade - Camshaft - 27-04-14 Can be a bit slow down here, long way for those waves to travel ! I like the 126's with the 20-22mm rise they give - more for the better look more than anything else :lol Re: Another question about the R6 shock upgrade - Super_Monkey - 27-04-14 hey hey Camshaft, Luke mentioned your on the other side of the football, I fitted the shock yesterday when you were probably sleeping anyway, gonna see how I get on with it and the standard dogbones and if need be I'll give the others a go, cheers for the reply.
