nitron shock problem - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: nitron shock problem (/showthread.php?tid=68373) |
nitron shock problem - carlos - 23-04-14 hi foccers I have just managed to fit my nitron shock to my 99 fzs but have found the bottom shock bolt just a bit to short with the thicker shock fittings on the nitron the mountings are about 2 mm thicker either side. this means the nut cant fully get on the bolt. any on else had this issue?? it will go on fully if I leave the washer off is this a good idea?? Re: nitron shock problem - carlos - 23-04-14 I thought about that but am concerned the bottom shock bolt takes a heavy load so should it be high tensile? or stainless Re: nitron shock problem - midden - 23-04-14 (23-04-14, 09:24 PM)carlos link Wrote: I thought about that but am concerned the bottom shock bolt takes a heavy load so should it be high tensile?So ask for a longer high tensile or stainless bolt ![]() No engineering firms nearby? Re: nitron shock problem - carlos - 23-04-14 looks like I will be looking for decent engineering firm tomorrow Re: nitron shock problem - Punkstig - 24-04-14 Are you sure you didn't get the bolts mixed up by mistake? My nitron fitted fine with the standard bolts! Re: nitron shock problem - carlos - 25-04-14 to late its on with thinner washer and Loctite for good luck didn't get them mixed up punkstig seems to be ok |
