Overflow pipe? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Overflow pipe? (/showthread.php?tid=68330) |
Overflow pipe? - hightower - 21-04-14 Another thread, but hopefully a quick answer for you all. You know the little rubber bowl under the tank that I think is supposed to catch overflow? That connects to a metal bracket that also holds the airbox on at the front. However, should that metal bracket then have a pipe coming off it? And if so, to where? Just mine hasn't, never has - I guess anything out the overflow will just dump straight down on the engine - should it run to the carb or something instead? Re: Overflow pipe? - Punkstig - 21-04-14 Should have a rubber pipe running down to around the centre stand mounts. Chances are its still there just not connected to the bowl! Re: Overflow pipe? - hightower - 21-04-14 But other than being connected to the bracket, the other end is free to dangle? I will do a search tomorrow for it, probably was there truth be told, but if not I'm sure I could find some tube easy enough. |
