Engine cutting out under hard acceleration. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Engine cutting out under hard acceleration. (/showthread.php?tid=68297) |
Engine cutting out under hard acceleration. - slappy - 20-04-14 I had previously posted about a misfire under hard acceleration on my gen1. I did all the suggestions offered to cure it such as draining float bowls, cutting 1/2" off ht cables and checking air filter was clear. The problem disappeared for a few weeks but now the engine is cutting out under hard acceleration. The engine will restart immediately afterwards on the button and runs perfectly the rest of the time. Anybody have any idea what could be the cause? Re: Engine cutting out under hard acceleration. - Mick-H - 20-04-14 Sounds like fuel starvation, check fuel line for kinks. Re: Engine cutting out under hard acceleration. - Dave48 - 20-04-14 If fuel system-tank/hoses/breathers/pump/filter/carbs ok check Ht leads/caps Re: Engine cutting out under hard acceleration. - karlo - 20-04-14 Change the fuel filter http://yambits.co.uk/fzs1000-fazer-fuel-filter-p-2234.html Re: Engine cutting out under hard acceleration. - fazer390 - 25-04-14 I had exactly the same issue the other month... Turned out to be the Datatool System 3 Alarm!!! :rolleyes Re: Engine cutting out under hard acceleration. - slimwilly - 25-04-14 Weak spark syndrone!!!!
Re: Engine cutting out under hard acceleration. - Sannox - 28-04-14 Check plug cap resistances, had similar on my foxeye 600 but not the whole engine dying, dropped a cylinder under hard acceleration (for a 600 :-) turned out to be a weak spark due to high plug cap resistance, ran ok otherwise. |
