High End missing - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: High End missing (/showthread.php?tid=68282) |
High End missing - gregwillclark - 19-04-14 Afternoon all! I Finally got the fazer back from the garage today after quite a bit of work. All ses to be running well after an 80 mile ride around Brecon, but I did notice a bit of hesitance at the top end when overtaking a car on the motorway. I took it up to around 9.5k rpm and it was pulling like a train, then suddenly it felt like it hit a brick wall and it started missing, opened the throttle a bit more and a suddern surge of power! It's very strange, was wondering if the HT leads or rectifiers could be breaking down under heavy load?? Greg Re: High End missing - Punkstig - 20-04-14 Sounds like it's dropping a cylinder, after its warmed up spray/ throw a bit of water on the exhaust headers, if one takes longer to dry off that points to the cylinder with the problem Re: High End missing - gregwillclark - 20-04-14 All cylinders firing fine at low revs and tick over. Re: High End missing - gregwillclark - 20-04-14 Anyone know if the coils can cause this?? Anything I can do to diagnose the issue? Re: High End missing - Sanchezz - 22-04-14 Looks like air filter problem to me. Some say this is hiflo air filter issue. Just my two cents though.. Re: High End missing - MarkWales - 24-04-14 Any improvement? Re: High End missing - gregwillclark - 24-04-14 Not sure yet, Ive changed the plug caps to new NGK's from M&P, also adjusted the TPS as this was showing 10k rather than 5 so I will hopefully find out this weekend.
