Broken key on Givi box - removal? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Broken key on Givi box - removal? (/showthread.php?tid=68247) |
Broken key on Givi box - removal? - goldfazer - 17-04-14 [img height=153 width=256]http://www.it-helps.co.uk/fazer/lock.jpg[/img] Seem to have half a key in the lock. And the thing is locked shut. How can I remove it? Broken key on Givi box - removal? - Exupnut - 17-04-14 If u got the snapped bit still.... Industrial super glu or liquid metal but I'd go for the super glue as it wont seep out so much when u hold it to dry. (And if u get the proper stuff "CA" from a modelling shop it will dry VERY QUICK) if of course u ask for the quick dryin stuff lol but if manage to foc it up new lock for 20 quidish. Re: Broken key on Givi box - removal? - Punkstig - 17-04-14 Had to do this the other day, The key has horizontal grooves down it, push the tab that protects the mech from dirt to one side, use super glue on an un bent paperclip and push it down the groove of the key. If the mech is still locked then use two paperclips down both grooves to turn key to open! You can then pull the broken bit out! Re: Broken key on Givi box - removal? - goldfazer - 18-04-14 Cheers, superglue was my backup, looks like it's #1 !! Re: Broken key on Givi box - removal? - Gingernutz - 18-04-14 If you get stuck they drill out Martin and I have a spare lock somewhere in the mess we call the garage Re: Broken key on Givi box - removal? - goldfazer - 20-04-14 Ta. Just off to try now.... Re: Broken key on Givi box - removal? - goldfazer - 20-04-14 Glue ain't gonn a work - how do I drill it out then? Re: Broken key on Givi box - removal? - goldfazer - 20-04-14 OK - sorted. The box wasn't mounted on the rack, so I unscrewed the fitting bit from the underneath (4 screws) - a few springs and bits may free themselves..... A bit a wiggling and this can be removed. The locking mechanism can them be 'opened' to reveal the rear of the lock barrel. Remove the circlip and the barrel can be removed - then just push the key back out. Re: Broken key on Givi box - removal? - Exupnut - 20-04-14 Where's the fun if you dont glue your finger to something... |
