Bike doesn't want to go into neutral when running...? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Bike doesn't want to go into neutral when running...? (/showthread.php?tid=68121) |
Bike doesn't want to go into neutral when running...? - papercutout - 08-04-14 It's a bit strange really isn't it? I can pop her into neutral easy as pie once the engine is turned off, but with it running I cannot get her into neutral from 1st, I tend to stick her in 2nd and give her a tiny kick down. I've got my clutch biting point pretty close to the bars, could this be the cause? Any other idea's? Re: Bike doesn't want to go into neutral when running...? - His Dudeness - 08-04-14 How's your chain? A slack chain can cause this problem. Also try slackening your clutch cable a little. That will bring the biting point of the clutch back closer to the handlebar Re: Bike doesn't want to go into neutral when running...? - dazza - 08-04-14 Tick over too low ? My bike does this if the idle revs are too low. Re: Bike doesn't want to go into neutral when running...? - johna6968 - 08-04-14 If the clutch biting point is almost at the bars then I would say its in need of adjustment and wont be helping the problem.. Re: Bike doesn't want to go into neutral when running...? - papercutout - 08-04-14 I'll be riding to work very shortly (damn night shifts), so I'll adjust the biting point then, and we'll have to see. The chain is fine, I retensioned it the other day. Tickover seems fine too. About 1K. Re: Bike doesn't want to go into neutral when running...? - dazza - 08-04-14 I could be wrong but 1k sounds low to me, it's certainly too low for a thou, don't know about the 600's. Can anyone confirm this ? . Re: Bike doesn't want to go into neutral when running...? - johna6968 - 08-04-14 Usually aim for 1200 rpm idle (hot)... Re: Bike doesn't want to go into neutral when running...? - Punkstig - 08-04-14 There should only be 5mm freeplay at the clutch lever. You obviously don't do many clutchup wheelies with the biting point back there! ![]() Oh, and I assume you're using four fingers not two! Re: Bike doesn't want to go into neutral when running...? - fazersharp - 08-04-14 Biting point sounds a little too much. Somtimes when comming to a quick stop I can find- finding netural being a bit iffy somtimes, maybe because im lost as to what gear im in or was when I stopped. I think I end up doing what you do and from 1st kick up to 2nd and then "tap" down but I think its only when Ive stopped in a hurry. Re: Bike doesn't want to go into neutral when running...? - papercutout - 09-04-14 I adjusted the biting point out a little last night, and there was no difference. I'll do it a bit further tonight to see if that helps. I don't do any wheelies, I know my limits, and I'd rather not make a tit of myself (5mm isn't that comfortable, I ride the bike in all weathers, and when it was bitterly cold I wanted as little movement of my fingers from the heated grips as possible! lol)
