Cam timing - advice please! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Cam timing - advice please! (/showthread.php?tid=68064) |
Cam timing - advice please! - Lawrence - 05-04-14 Not sure this is right and would explain my shitty running, can anyone say for sure? Thanks very much
Re: Cam timing - advice please! - Lawrence - 05-04-14 Actual cam lobes visible in these photos. Re: Cam timing - advice please! - Fazerider - 05-04-14 The lobe position diagram in the manual is a little unclear and it's hard to judge accurately from photos, I'm suspicious of the inlet timing in particular though can't imagine it would be running at all if it's as far out as it looks to me. Can you see the timing mark on the cams? Bear in mind the cams run at half engine speed so you may have to give the crank another turn. Re: Cam timing - advice please! - Lawrence - 05-04-14 It's running like a complete sack of crap at the moment, won't go over about 55 mph. I'll take another look... Cam timing - advice please! - Lawrence - 05-04-14 The black dots on the cam shafts line up exactly with the little prong things on the cam cap: ![]() The crank is lined up spot on too so looks like it's all good. It certainly looks off to me but if it's all lined up right... Re: Cam timing - advice please! - His Dudeness - 05-04-14 It's hard to tell from your pictures, your eye has to be dead inline with the markings to get a true idea. Are you saying everything lines up correctly but it looks off? How's that? Re: Cam timing - advice please! - Lawrence - 05-04-14 The marks line up when looking at them straight on, it just looks like the cams are out of position ![]() Back to the drawing board I guess, either that or it's going on ebay. Re: Cam timing - advice please! - unfazed - 05-04-14 If the dots on the cam and cam cap marks do not line up it is usually caused by a worn cam chain. However the FZS600 will run happily with the marks out by the very small amount you have shown in the picture. The wear on my chain had the cam timing out by one tooth before I changed it and it still ran cleanly to the red line, but rattled like Foc You certainly have the signs of a worn cam chain. I think your problem is elsewhere. What mileage is on the bike? Did it happen suddenly or over a few weeks. What did you change before it happened? Check Clogged air filter, Something under the seat blocking the air filter inlet Clogged fuel filter Kinked fuel line Some body put restrictors in when you were not looking :lol Water in the fuel (a lot of it) Intake manifolds leaking Diaphragms perforated Coil or plug cap issues Make sure caps screwed on the leads fully. Loose or corroded electrical connections Dodgy or worn plugs. Valve clearances incorrect Worn valve seats Compression low Check the simple things first as the list is almost endless. Re: Cam timing - advice please! - Fazerider - 05-04-14 Ah! I've just worked out the difficulty I had with the manual drawing... It's drawn as a plan view to show the timing marks, but inlet and exhaust are shown independently, so not as they actually appear when looking down on the top of the engine. The end-on view showing the lobes has top at the left (indicated by the continuation of the construction line). So your cams look as they should. Re: Cam timing - advice please! - red98 - 05-04-14 From what I can see in the pictures..all looks good......cam marks have to be spot on with the prongs with the cam lobes on no1 cylinder facing away from each other, T mark has to align with the join of the upper and lower crankcases......have you had the cams out reacently ? Re: Cam timing - advice please! - Lawrence - 05-04-14 (05-04-14, 01:22 PM)unfazed link Wrote: If the dots on the cam and cam cap marks do not line up it is usually caused by a worn cam chain.I'll get my compression tester in it if I can and see what that gives. Would be nice to get it back on the road at some point... (05-04-14, 02:37 PM)red98 link Wrote: From what I can see in the pictures..all looks good......cam marks have to be spot on with the prongs with the cam lobes on no1 cylinder facing away from each other, T mark has to align with the join of the upper and lower crankcases......have you had the cams out reacently ?Nope, never. Which is why I was worried if they were wrong, how had it happened. Re: Cam timing - advice please! - unfazed - 05-04-14 Check the choke is working correctly and all the plungers return fully. Check the float heights with a clear plastic tube attached to the drain hole. Hold it up the side and fuel should line up near the top of the float bowl. If looks wrong start the bike and the fuel should settle before getting worried :-) If compression checks out then it looks like dirty carburettors, like the emulsion tubes or main jets Pull all the connectors in the box under the tank and give them a quick spray of WD40. Valve clearance would really want to out of adjustment by a long way to have effects on running. As you have the cam cover off you may as well check them. |
