Rear wheel/axel noise - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Rear wheel/axel noise (/showthread.php?tid=68034) |
Rear wheel/axel noise - Gary - 03-04-14 Well guys .. my FZ1 has developed a squeak at the back wheel. At first I thought it could be the disc being warped but the noise is coming from the opposite side of the wheel - more so in where the axel is. Im going to remove the wheel and axel but want to put some grease on it - which grease should I use? If I find the grease doesnt fix it - I might change the axel/wheel bearings. Is this a handy job for a novice? Re: Rear wheel/axel noise - dazza - 03-04-14 I use molyibniu molibnium molybnium The black one.
Re: Rear wheel/axel noise - Gary - 03-04-14 I'll hit the motor factors so and ask for the black stuff .... or the bar first and ask for the same :rollin Re: Rear wheel/axel noise - Tmation - 04-04-14 If you don't have a workshop manual download it from on here http://foc-u.co.uk/index.php?action=downloads;sa=view;down=12 It will tell you what oils and greases etc you should be using plus how to remove rear wheel/change bearings etc. Not sure what it says in the manual (i have gen 1) but I normally use high temp lithium grease for wheel bearings. good luck. Re: Rear wheel/axel noise - PaulSmith - 04-04-14 The only thing in there that squeaks are the bearings, (http://www.yamahamotorcyclespares.co.uk/genuineparts/9023/31/yamaha%20fzs1000%20fazer/rear%20wheel?uID=0) (parts 13, 6 and 2) and if they are squeaking, it is probably a bit late for lube. You can try and put some lube in anyway as that might help delay the failure, but I suggest you order replacement bearings now. If you have done it before, and you have (or can borrow ) a puller, it is less than an hours work to replace the bearings. Do you use a powerwasher? If so, you might as well consider replaceing the front bearings while you are at it, as they are probably dried out aswell. |
