Help! Camshaft - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Help! Camshaft (/showthread.php?tid=67986) |
Help! Camshaft - hightower - 31-03-14 Got holders off, go to pull camshaft up but not coming. Lifted slightly on right, but not coming on the side nearest the alternator. Have I missed something? Don't want to pull too hard Re: Help! Camshaft - hightower - 31-03-14 Ok, cam shafts loose now but not enough slack in chain to remove them? Re: Help! Camshaft - red98 - 31-03-14 Top and front guides off , tensioner out ?.......if yes now that the chain is loose make sure its not caught up in the bottom end , also try rotating the shaft as you try to removeĀ y
Re: Help! Camshaft - hightower - 31-03-14 Yay! Got it off with a little patience. Front cam chain guide needs to come out according to manual, but won't physically fit to come out with engine in situ - had to pull head up a bit then pull cam guide out. Anyway, head off so drilling time tomorrow
