Valve Cleaning - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Valve Cleaning (/showthread.php?tid=67979) |
Valve Cleaning - hightower - 31-03-14 It's been suggested I clean the valves whilst the head is off. What's the best way to do this (what solutions/tools to clean?), and do I need to replace the valve stem oil seals or can they be reused if in good nick? Re: Valve Cleaning - hightower - 31-03-14 So watched a few videos, and it seems lapping/grinding is what I need, with something like this: http://www.ebay.co.uk/itm/HOLTS-VALVE-GRINDING-KIT-SET-LAPPING-STICK-TOOL-COARSE-FINE-GRADE-PASTE-/231129077484?_trksid=p2054897.l5661 I'm going to order the kit now, but has anybody else done this? I'm guessing from the videos I watched that it's straight forward enough job, just time consuming. Re: Valve Cleaning - Dead Eye - 31-03-14 Yep, straight forward enough job but is time consuming... I've managed 8 of the 16 valves in 10 months... woops... You will also need a valve spring compressor if you don't already have one May as well check all the valve gaps and shims whilst you are at it
Re: Valve Cleaning - savvy - 31-03-14 To clean up valve heads,pop valve in a drill, low revs, fine emery and CAREFULLY remove any carbon deposit. Don't go up the stem, usually there is a step onto the stem where it fits the guide.Stay off the guide part. It helps to have the drill in a vice or workmate clamped solid. Better still a pillar drill or drill stand to take a pistol drill. Don't wrap emery over the valve or you may trap fingers in it if it grabs, use emery flat. GO STEADY |
