Hunting at 3500 rpm - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Hunting at 3500 rpm (/showthread.php?tid=67969) |
Hunting at 3500 rpm - nickodemon - 30-03-14 Bought myself a standard fazer 1000 gen 1 and it is really good. I've been using it for a few days now and the only slight issue is it seems to be hunting slightly on a steady throttle at 3500 rpm. It's so long ago when i last rode a standard fazer i can't remember if this was a common problem or if there is a solution. The only thing i could think of was old fuel as the bike had covered less than 300 miles in 3 years? I have fitted a venom race can with the front db killer in and the rear one out. Ps.. It seems to be slightly worse when it's cold. Re: Hunting at 3500 rpm - Falcon 269 - 30-03-14 Hi Nick Sounds like a combination of lean surge, made worse by partially blocked pilot jets. What year is the bike? If it's a 2002/early 03, they suffered worst from lean surge. Try some carb cleaner in the fuel first. Re: Hunting at 3500 rpm - nickodemon - 30-03-14 Hi Mike, It's an '02. It isn't too bad it sounds like it's hunting but doesn't cause the bike to judder. Whats the best carb cleaner to put in fuel. I have redex injector cleaner. Could i stick some of that through the fuel system? Re: Hunting at 3500 rpm - Falcon 269 - 30-03-14 No personal experience but I gather that Redline fuel cleaner (see ebay) is the stuff that works. ![]() Try that first and then we can take it from there. Re: Hunting at 3500 rpm - nickodemon - 30-03-14 I'll order some off fleabay. I asked about injector cleaner because i thought it may be similar stuff
Re: Hunting at 3500 rpm - unfazed - 31-03-14 Out of balance carbs makes it even worse Re: Hunting at 3500 rpm - nickodemon - 31-03-14 Tickover is slightly unsteady, as if they are slightly out of balance. Re: Hunting at 3500 rpm - nickodemon - 06-04-14 Put some carb cleaner through the bike and thrashed it silly. :lol Seems to have sorted it
