Sheared rad lug - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Sheared rad lug (/showthread.php?tid=67966) |
Sheared rad lug - dazza - 29-03-14 Went to fit a s/s rad guard today. A glance at the Phillips screw heads at the bottom two days ago I just knew it was going to be a PITA. So, been spraying them with penetrating fluid and had a crack at it today. One cracked off ok, the other wasn't having it. Tried heat, more penetrating spray, gave a gentle whack with an impact driver but didn't like doing it on the rad. Ended up chewing up the head so out came the grinder. cut a slot in the head and gave it some with a flat head. Not having none of it. The next step was to grind off the head, centre punch and drill out and find my stud extractor set. I ran out of options when the lug sheered off when I was ay the stud extractor stage. So, can I get the lug or a new one brazed or welded on to my rad or shall I just rely on my little dob of silicone to keep it in place ? Then to top it all I noticed a thick steel staple in the rear tyre that hissed at me when I attempted to remove it. Too late to get it repaired, needless to say it got pushed back in. :wall Today, was not a good day but I should have known not to touch anything mechanical after my works van blew a hole in the gearbox on Friday. :oops Re: Sheared rad lug - chaparral02 - 30-03-14 (29-03-14, 08:49 PM)dazza link Wrote: So, can I get the lug or a new one brazed or welded on to my rad or shall I just rely on my little dob of silicone to keep it in place ?If your rad has copper/brass end tanks then it should be very easy for someone to solder a new lug back on... But if the rad end tanks are plastic then your going to have to try gluing it back on.. Sorry i can't remember what my gen1 rad end tanks where made of... :o Re: Sheared rad lug - Red Ceri - 31-03-14 Dazza, you could always try one of these DIY 'welding' kits, http://www.ebay.co.uk/itm/DURAFIX-EASYWELD-2-ROD-LOW-TEMPERATURE-ALUMINIUM-WELDING-REPAIR-KIT-BRUSH-TUBE-/221389856896?pt=LH_DefaultDomain_3&hash=item338bdd2080#ht_2130wt_1399 Re: Sheared rad lug - dazza - 31-03-14 Thanks for the replies, I 've just checked the broken lug and it appears to be plastic. Now, where's my araldite.
