how to check tps - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: how to check tps (/showthread.php?tid=67947) |
how to check tps - nickodemon - 28-03-14 Hi, Been ages since i last checked tps. How do i do it? :lol Re: how to check tps - Falcon 269 - 28-03-14 You check Pat's Site first.
Re: how to check tps - bristol banger - 28-03-14 (28-03-14, 07:44 AM)Falcon 269 link Wrote: You check Pat's Site first. A wealth of knowledge on Pat's site :thumbup On my list of jobs for today balance carbs and check tps, I'm going to try Ivans method for the tps adjustment. Not done it that way before has anyone found it beneficial? Re: how to check tps - Falcon 269 - 28-03-14 Yes, and yes. However, I suggest you set the TPS to the 5k standard position first and scribe a line between TPS unit and the mounting plate so that you can always return to that setting without having to lift the tank etc. Now experiment with the TPS setting as per Ivan's instructions to your heart's content.
Re: how to check tps - jason1 - 28-03-14 Ill be doing mine soon as need new carb rubbers and carb balance, just wondering what tool i need to undo TPS? Re: how to check tps - nickodemon - 28-03-14 (28-03-14, 07:44 AM)Falcon 269 link Wrote: You check Pat's Site first. Ta.
Re: how to check tps - Falcon 269 - 28-03-14 (28-03-14, 11:42 AM)jason1 link Wrote: Ill be doing mine soon as need new carb rubbers and carb balance, just wondering what tool i need to undo TPS? T-20 Torx security bit. Like it says on Pat's Site ... :'( Re: how to check tps - nickodemon - 29-03-14 He he.... Re: how to check tps - nickodemon - 30-03-14 Tps adjustment is fine
