Indicator Flashing Too Fast - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Indicator Flashing Too Fast (/showthread.php?tid=67933) Pages:
Indicator Flashing Too Fast - hightower - 26-03-14 So I've had this intermittent issue on my right indicator only, left is fine. Basically, it works sometimes as normal, then other times it flashes fast and the front indicator doesn't flash (rear does). Obviously it's not the bulb because it does work other times. Sometime's if I leave it on it will flash fast for a bit, then normal, then fast. It sounds like a loose connection, but I have had the indicator out the front before to have a look and couldn't see anything obvious - gonna be fun diagnosing/finding the issue. Re: Indicator Flashing Too Fast - stevierst - 26-03-14 It does sound like a loose/corroded connection somewhere. (Just tell me to shut up if your good with electrics) Start with the basics such as the multi plugs, fuse connection, and the relay. (my heated grips stopped working, and it was a corroded fuse!) If they're ok,the it's trace the wires back and see if there's any breaks, splits or areas where they've worn through and touching metal. Good luck with it! Re: Indicator Flashing Too Fast - Ruby Racing - 26-03-14 I'd say definitely a loose connection somewhere. The only reason the indicators flash fast is if one is not working, so that points to a loose connection. Re: Indicator Flashing Too Fast - hightower - 26-03-14 No Stevie, don't shut up. I'm absolutely terrible with electrics. I hate them Re: Indicator Flashing Too Fast - robby boy - 26-03-14 Check all connections, I would also check the bulb holder and maybe change bulb, I have seen bulbs with broken filaments that make contact now and again so work intermittently. Re: Indicator Flashing Too Fast - His Dudeness - 26-03-14 Start at the bulb. It's probably just loose or has a bit of corrosion around it Re: Indicator Flashing Too Fast - esetest - 26-03-14 Start with the bulb first , swap it with the one you know that's working , then check bulb holder for corrosion , then check other connections . Re: Indicator Flashing Too Fast - hightower - 26-03-14 Obviously the biggest issue is with it not being all the time. You think it's sorted, to find 2 days later that it isn't. Re: Indicator Flashing Too Fast - elbrownos - 26-03-14 Indicators always flash at double speed when a bulb is blown/missing/etc.. It's the same with cars. Re: Indicator Flashing Too Fast - hightower - 27-03-14 I know that, but the problem is the bulb is not missing (sure I've covered that already)... Re: Indicator Flashing Too Fast - dcurzon - 27-03-14 Is the bulb missing? Re: Indicator Flashing Too Fast - richfzs - 27-03-14 (26-03-14, 06:56 PM)robby boy link Wrote: and maybe change bulb, I have seen bulbs with broken filaments that make contact now and again so work intermittently. And so have I, don't discount the bulb as a possibility... Re: Indicator Flashing Too Fast - His Dudeness - 27-03-14 Tie a brick around it, that should slow it down Re: Indicator Flashing Too Fast - stevierst - 27-03-14 (27-03-14, 10:28 AM)His Dudeness link Wrote: Tie a brick around it, that should slow it down ![]() ![]() ![]() oh a bit of wee just came out. Lol
Re: Indicator Flashing Too Fast - Ruby Racing - 27-03-14 (27-03-14, 04:36 PM)stevierst link Wrote: [quote author=His Dudeness link=topic=12325.msg137543#msg137543 date=1395912501] ![]() ![]() oh a bit of wee just came out. Lol[/quote] That's just an ageing thing! :\ Re: Indicator Flashing Too Fast - richfzs - 27-03-14 He's got a thou.... Re: Indicator Flashing Too Fast - hightower - 27-03-14 (27-03-14, 10:28 AM)His Dudeness link Wrote: Tie a brick around it, that should slow it down You must have gone to the same electrical college as me :rollin Ok, so after I fit my stainless pipes tonight I'll try tying a brick around in first. If that doesn't work I'll change the bulb, and then start and trace it all the way back. Re: Indicator Flashing Too Fast - stevierst - 27-03-14 (27-03-14, 04:45 PM)Ruby Racing link Wrote: That's just an ageing thing! :\Oh you guys crack me up, I'm only 21 (ish) : :-*
Re: Indicator Flashing Too Fast - Ruby Racing - 27-03-14 (27-03-14, 04:57 PM)stevierst link Wrote: Oh you guys crack me up, I'm only 21 (ish) : Oh you poor chap, it's started a LOT earlier for you. Never mind. :lol Re: Indicator Flashing Too Fast - ChristoT - 27-03-14 (27-03-14, 05:19 PM)Ruby Racing link Wrote: [quote author=stevierst link=topic=12325.msg137596#msg137596 date=1395935876] Oh you poor chap, it's started a LOT earlier for you. Never mind. :lol [/quote] Oh shit, you're worrying me now! :lol :lol |
