renthalls - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: renthalls (/showthread.php?tid=67899) |
renthalls - carlos - 23-03-14 okay here's a question, changed my fzs600 to renthal ultra lows but they do strike the fairing at full lock I have seen other fazers with low and medium renthals how do these match up to the originals?? and do they foul the fairing is there a massive change in riding position?? I think it will fail an MOT if the bars hit the fairing any ideas Re: renthalls - Chris - 23-03-14 Can you loosen the bolts at the centre of the bars and rotate them back towards you a bit? should stop them touching the fairing. You'll need to adjust the switch gear and levers again though. Chris Re: renthalls - stevierst - 24-03-14 I've fitted them to all three of my boxeyes, two of them the bars touched, and one barely cleared. You've got to roll the bars back slightly in the clamps, I also found that twisting the throttle tube mount round helped with clearance a bit. It's certainly a close one, bit they've always passed the mot. Re: renthalls - johna6968 - 24-03-14 The angle of sweep on the superbike lows is significantly more than the ultra lows.. Renthal site i believe gives dimensions.. Trying a pair fazer thou bars on the boxeye. No holes to drill or lugs to file off and enough rearward sweep to put a wheelbarrow to shame :lol Re: renthalls - carlos - 24-03-14 cheers guys may be trying some low renthals in place of ultra lows |
