Rear Light - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Rear Light (/showthread.php?tid=67872) |
Rear Light - theglove1978 - 22-03-14 Afternoon all. Liverpool losing so i have abandoned the football and looking at small problem on t'Fazer. When starting the bike and with the lights switch in off position, there is no front light (fine) but a bright rear light. The only thing is that when i apply the brake, both rear and front, the light barely changes intensity to register the brake. Thoughts? Also (and i risk sounding potentially stoopid) should the rear light be on when switch in off position? Re: Rear Light - imax - 22-03-14 Sounds like it could be a stuck brake switch (most likely the rear) No stupid questions here, you're just the one who had the guts to ask! Re: Rear Light - theglove1978 - 22-03-14 Phew! Suspected the rear switch. Time to get the Haynes manual out. Re: Rear Light - dcurzon - 22-03-14 Give the rear brake a good clean and maybe adjust the pedal up a touch |
