Steering lock problem - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Steering lock problem (/showthread.php?tid=67811) |
Steering lock problem - wheelywill - 19-03-14 Hi have a prob with my ignition its fine just to turn the ignition on but if I turn the key over to the left to put the lock on that's fine BUT when I try to get it off that's when the problem arises yesterday it took at least 10 minutes today I was 20 minutes anyone have any ideas :'( Re: Steering lock problem - tex - 19-03-14 could be a bit of grit inside, try and flush it with wd, using the small tube supplied Re: Steering lock problem - NorthWestern - 19-03-14 Mine is like that, I used the lock twice, once the first time I rode it to work and then once when I got home to double check. Both times took a good few mins of jiggling to get it off. I have tried cleaning it, carbon lock lubricant etc They did make a bit of difference but not to the point that I am comfortable putting the lock on... My key does look quite worn though, perhaps that is part of the problem. Re: Steering lock problem - old son - 20-03-14 WD40 worked for me. Scottoil didn't!!! Re: Steering lock problem - Lank - 20-03-14 (19-03-14, 08:33 PM)tex link Wrote: could be a bit of grit inside, try and flush it with wd, using the small tube supplied I had this two weeks ago after the bike was sat for about 3 weeks. Petrol cap done the same, WD40 on both sorted it out straight away Re: Steering lock problem - noggythenog - 20-03-14 8) Re: Steering lock problem - Simon.Pieman - 20-03-14 The same happened to me a while ago and despite emptying half a can of WD40 through the lock and then lubing with graphite it still got stuck and took me a few minutes to free it. I never use the lock now, it's tempting fate, also the lock is so easy to break with a swift kick to the bars it's probably not worth using -I always use a disc lock everywhere anyway. Re: Steering lock problem - wheelywill - 20-03-14 Thanks to everyone for your comments, I myself have tried wd40 lots of and also tried the expensive stuff acf50 things haven't got any better so im very reluctant to use it again so I will invest in a chain and lock cheers Dave Re: Steering lock problem - PaulSmith - 24-03-14 If the ignition works fine then it is probably not a problem with the lock barrel but with how the bolt interacts with the frame. |
