Cylinder head replacement engine out? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Cylinder head replacement engine out? (/showthread.php?tid=67804) |
Cylinder head replacement engine out? - Screwdriver - 19-03-14 Do I have to whip the engine out to replace the cylinder head on my Gen 1 Fazer Thou? Cheers S. Re: Cylinder head replacement engine out? - Tmation - 19-03-14 Download the service manual from on here. http://foc-u.co.uk/index.php?action=downloads;sa=view;down=11 Re: Cylinder head replacement engine out? - Dead Eye - 19-03-14 I don't think so - I'm pretty sure you can do it in situ. I know you can on the 600 at least... Re: Cylinder head replacement engine out? - unfazed - 19-03-14 (19-03-14, 02:22 PM)Screwdriver link Wrote: Do I have to whip the engine out to replace the cylinder head on my Gen 1 Fazer Thou? Yes, engine out job. :'( Re: Cylinder head replacement engine out? - kebab19 - 19-03-14 Eh? No way, I replaced the head on my 1000 after a very rare water pump failure & I can assure you the lower lump stayed in situ Re: Cylinder head replacement engine out? - Screwdriver - 19-03-14 Wow. That's brilliant, thanks for the link to the service file. I have a Haynes that says take it out but it looks sort of doable, depends on the length of the remaining studs I guess. I would like to hear from someone who has definitely done it though because it does look really tight. I have only just replaced the gearbox, only for a cap cap to shatter a week or so later. I hadn't even taken the head off... [smg id=1797 type=preview align=center caption="fazer cam cap"] Screwd. Re: Cylinder head replacement engine out? - Screwdriver - 19-03-14 (19-03-14, 07:14 PM)kebab19 link Wrote: Eh? Sorry kebab, just noticed you have actually done this before. Many thanks. I'll nip out to the shed now and whip the head off. Re: Cylinder head replacement engine out? - unfazed - 19-03-14 Last time I did one with a friend whose engine dropped a valve, he took the engine out before I got there and he said he could not get the clearance over the top of the studs when he tried to lift off the head. Good to know from someone who has done it for future reference. ![]() Re: Cylinder head replacement engine out? - Screwdriver - 19-03-14 Confused now. Referring to the service manual. To remove the cylinder head: Step 1, take out the engine.... So kebab, you've taken the cylinder head off a Gen 1 Fazer Thou without taking the engine out? The cylinder head (the big part with all the valves in it, not the head cover) clears the studs before it hits the frame? Re: Cylinder head replacement engine out? - Screwdriver - 19-03-14 (19-03-14, 08:05 PM)unfazed link Wrote: Last time I did one with a friend whose engine dropped a valve, he took the engine out before I got there and he said he could not get the clearance over the top of the studs when he tried to lift off the head. Exactly what I was thinking. It looks like it nearly does... ...but there is about 10mm of doubt. Re: Cylinder head replacement engine out? - Screwdriver - 20-03-14 So it is possible. But you have to remove the righthand exhaust stud which fouls the frame. Found the culprit. A small bolt got in there. Also, while the engine was upside down having its gearbox replaced, all the crud deposited itself in the oil ways. Live and learn. S. Re: Cylinder head replacement engine out? - unfazed - 21-03-14 A bit of JB Weld and it will be fine. :lol I showed my friend the picture with the engine in situ and the head off. His reply was FOC :wall should have waited till you (meaning me) arrived ![]() Re: Cylinder head replacement engine out? - Falcon 269 - 22-03-14 Bet that sounded nice before it finally decided to stop.
Re: Cylinder head replacement engine out? - Screwdriver - 24-03-14 (21-03-14, 09:02 PM)unfazed link Wrote: I showed my friend the picture with the engine in situ and the head off. His reply was FOC :wall should have waited till you (meaning me) arrived Why? Re: Cylinder head replacement engine out? - unfazed - 24-03-14 He did not realise the exhaust studs could have been removed without out breaking them. :eek Re: Cylinder head replacement engine out? - Screwdriver - 27-03-14 (22-03-14, 06:24 AM)Falcon 269 link Wrote: Bet that sounded nice before it finally decided to stop. Started off being a noticeable ticking, then, with a cold engine, really poor performance. Finally a mad dash down the M1 at the end of which it sounded like a badly adjusted cement mixer. Very lucky to bag a really nice looking complete head off eBay. In black too for £80. S. Re: Cylinder head replacement engine out? - midden - 27-03-14 (20-03-14, 01:38 AM)Screwdriver link Wrote: So it is possible. So we can rest easy now, in the knowledge that Kebab does in fact know which part is the cylinder head after all (the big part with all the valves in it, not the head cover) :evil Nice pics btw Christo take note Re: Cylinder head replacement engine out? - Falcon 269 - 27-03-14 (27-03-14, 01:40 AM)Screwdriver link Wrote: [quote author=Falcon 269 link=topic=12196.msg136180#msg136180 date=1395465863] Started off being a noticeable ticking, then, with a cold engine, really poor performance. Finally a mad dash down the M1 at the end of which it sounded like a badly adjusted cement mixer. Very lucky to bag a really nice looking complete head off eBay. In black too for £80. [/quote] I'm amazed it ran that long, especially seeing the state of the cam bearing surfaces. I assume it's a full engine out and strip to clean all the cag from the oilways and oil pump. Good find with the new head.
Re: Cylinder head replacement engine out? - Screwdriver - 07-04-14 (27-03-14, 07:31 AM)Falcon 269 link Wrote: I'm amazed it ran that long, especially seeing the state of the cam bearing surfaces. I assume it's a full engine out and strip to clean all the cag from the oilways and oil pump. Good find with the new head. Nope. Just swapped the head complete, set the valve clearances, filled it up with oil and water, good to go. No regular updates because incredibly, there is nowhere in London with a head gasket in stock. The very next thing is to bolt down the new head so until I source a new gasket, the mission is on hold. I had hoped to reuse the old one but it looks like that has already happened a couple of time and it's looking a bit flat (!). I have cleaned and prepped the new head though. I'll try linking a few pics but photo bucket keeps claiming I have run out of bandwidth. A scam no doubt designed to force people to pay for this so called free web service... ![]() ![]() ![]() The exhaust stud which fouls the frame on assembly came out a treat. Should be running again within a few days, subject to sourcing a new gasket. Fifty bloody quid mind from Yamaha... S. Re: Cylinder head replacement engine out? - Screwdriver - 07-04-14 hmm. This seems to be one of the only forums I visit which doesn't rescale images. Thats a bit of a pain... |
