For sale Blue spot rear thousand caliper - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: For Sale & Wanted (https://foc-u.co.uk/mybb/forumdisplay.php?fid=80) +--- Thread: For sale Blue spot rear thousand caliper (/showthread.php?tid=67624) |
For sale Blue spot rear thousand caliper - bristol banger - 09-03-14 Hi all, I have a fazer thou Blue spot rear caliper for sale. Until yesterday it was fitted to my bike but I've now fitted some 5 spoke R1 wheels which required fitting an R6 caliper. The pads are low and need replacing £60 plus postage. Steve Re: For sale Blue spot rear thousand caliper - pilgo - 10-03-14 is this the upgraded caliper that would fit a box eye'd 600? plan to fit braided line to my rear brake soon,could do this as well. and im only 30mins from you,so could pick it up (assuming your user name actualy is where you live? ) Re: For sale Blue spot rear thousand caliper - bristol banger - 10-03-14 Yep it's the upgrade for the 600 and I live in yate on the outskirts of bristol
Re: For sale Blue spot rear thousand caliper - pilgo - 10-03-14 (10-03-14, 08:11 PM)bristol banger link Wrote: Yep it's the upgrade for the 600 and I live in yate on the outskirts of bristol yate is a part of Bristol i dont know to well,so fancy meeting else where-or pm me your number and i'll give ya a bell? Re: For sale Blue spot rear thousand caliper - Chris - 11-03-14 second dibs if Pilgo decides he doesn't want it. Thanks Chris Re: For sale Blue spot rear thousand caliper - bristol banger - 11-03-14 Number sent pilgo Re: For sale Blue spot rear thousand caliper - pilgo - 11-03-14 (11-03-14, 08:21 AM)bristol banger link Wrote: Number sent pilgo ring ya later
Re: For sale Blue spot rear thousand caliper - pilgo - 11-03-14 (11-03-14, 04:42 AM)Chris link Wrote: second dibs if Pilgo decides he doesn't want it. chris,any idea if this caliper fits to the existing hanger or do i need to upgrade that as well? just talked with Bristol banger and neither of us is too sure Re: For sale Blue spot rear thousand caliper - noggythenog - 11-03-14 (11-03-14, 09:08 PM)pilgo link Wrote: [quote author=Chris link=topic=12015.msg133406#msg133406 date=1394509373] chris,any idea if this caliper fits to the existing hanger or do i need to upgrade that as well? just talked with Bristol banger and neither of us is too sure [/quote] I bought one of these last week, apparently you use the new hanger, the one off the thou...but one of the bolts doesnt quite line up properly so it needs a tiny bit of persuasion....on the hanger to like scuff a bit off, i think fizzy was last to fit one & he said he used a small round file so a few quid from homebase or whatever. Now i have an even dafter question...lets also direct it at chris..he's a helpful foccer....is it possible to change a caliper without bleeding the whole brake system....do you just pinch the pipe & then bleed out a tiny bit of air....i aint got a clue. :o Re: For sale Blue spot rear thousand caliper - Chris - 11-03-14 You can use the 600 hanger but you need to file a small part off so the bolts line up with the 1000 caliper. There are pics of it somewhere on here. I'll have a look. If you're replacing just the caliper then by undoing the banjo bolt and attaching it to the replacement caliper then the brake system will still need bled. You wouldn't be able to pinch it closed and even if you did the caliper would still be full of air and need to be bled out. If you're not sure get someone to help who does know. If your brakes don't work you're as good as dead. Chris Re: For sale Blue spot rear thousand caliper - pilgo - 12-03-14 (11-03-14, 11:24 PM)Chris link Wrote: You can use the 600 hanger but you need to file a small part off so the bolts line up with the 1000 caliper. There are pics of it somewhere on here. I'll have a look. if you could find those photo's that would be triffic mate! i'll be changing the brake hose and fluid to stainless line and dot 5.1 so will need to bleed it anyway. just one more silly question-do i need a brake line for a fazer 6 or fazer thou as im changing the caliper to the blue dot? thanks in advance :o |
