help needed no lights - Printable Version
+--- Thread: help needed no lights (/showthread.php?tid=67542)
Pages: 1 2
help needed no lights - ashley101 - 03-03-14
hi can any one help me i have no lights on my fazer 600 i have only high beam . the flash button dont work no side lights no rear tail light.  all indicators work the brake lights work i have checked all bulbs and fuses everything there is ok ?? any help would be appreciated
thanks for viewing
Re: help needed no lights - red98 - 03-03-14
Fuse ?
Re: help needed no lights - bigbluebear - 03-03-14
Wiring????
Re: help needed no lights - john 087 - 03-03-14
did you try  turning off switch a few times. worked for me one night.
Re: help needed no lights - noggythenog - 03-03-14
I know nothing.....but in the interest of diagnostics what was the last job you did to your bike ie anything involving taking bits off, seat, tank, battery etc????
Re: help needed no lights - ashley101 - 03-03-14
yes i have checked fuses and i havent touched nothing there has been loads of rain if thats got anything to do with it because i cannot think what else it could be ill read your thread now and thanks for the replys
and yes john just went out a done it about 15 times still no luck mate
Re: help needed no lights - esetest - 03-03-14
If you haven't ,  might be worth downloading the manual , the section on the electrical system might help , could be dirty contacts in the switches .
ive downloaded it just as you said it aswell mate thanks im going to have to get it apart tomorrow when its light lol cannot see a thing now .. Smile
haha its too cold for me out there .. Wink going to have to make a day of it tomorrow Smile
thanks for your replies its appreciated
Re: help needed no lights - ChristoT - 03-03-14
A problem I had (with rear lights and sidelight only, true, but worth mentionning) was when a wire got cut at the ignition barrel by just wearing through. The rear and side lights go through the ignition barrel, as the lights use the park light circuit to run. A quick check round the ignition barrel, checking no wires are broken may save you 2 days of head scratching and some bottom clenching rides!!
christo you are the man i have just looked there is a blue/yellow stripe and looks like a blue have broke completley off i cannot even connect them back up. there is a brown red blue/red stripe and blue/black stripe they are all still in the ignition barrell is there anyway to bypass the wires just for the lights not bypass the ignition before anybody gets any funny idea's or new lockset time ???? thanks christo
It's a rare problem, it took me two agonising days of attacking the bike with a multimeter, and removing half the panels to find the issue! Glad it's saved you some time.
There are 2 wires that only do the park light (you'll have to check the wiring diag, I can't remember them off the top of my head). I just put a connector block between them in the Black Box of Wiring Hell under the tank. No problems with the electrics since, no way round the usual ignition, and it saved me £75 for a full lock set (who even uses the park light anyway?)
Re: help needed no lights - Skippernick - 03-03-14
FUCK ME………..
Christo has his uses, well done mate.
I'm going to ask a mod to put this thread on the front page to tell everyone. :lol
Result!
Re: help needed no lights - ashley101 - 04-03-14
sorry i just checked again its the straight blue wire and the blue/red wire
not the blue/yellow wire
thanks
Re: help needed no lights - ChristoT - 04-03-14
Ok....
The blue and red and the straight blue connect together when the ignition is on the "on" position. Connecting these two together in the under tank box should be fine, but you will then be able to turn your lights on with the ignition off. That's certainly a temporary fix, I'll have to double check the wiring diagram to confirm that's all you can do on that circuit (though I'm sure it is).
Re: help needed no lights - ashley101 - 06-03-14
yes mate thanks christo messaged me and told me what wires to stick together and its all good now thanks for all your help guys Smile
Re: help needed no lights - Tefer - 11-12-15
Hi,
Looks like i am experiencing this issue. I was tugged by the Police last night and he said i had no rear light, thought it was weird that both bulbs died, got to my old folks and it was back on so defo not a bulb issue. When was about to leave i checked the light and it was still working, great stuff, moved the bike and gone off again.
When i got home and was pushing the bike in to shed i noticed the bike light would come on when in position for steering lock but go off when straight, so looks like a broken wire that seems to connect in a certain position.
Can someone clarify the wire i am looking for coming out of the ignition?
Re: help needed no lights - BBROWN1664 - 11-12-15
Tefer - It could still be the bulb.
