Front forks - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Front forks (/showthread.php?tid=67538) |
Front forks - Nick Hood - 03-03-14 What is the best way of restoring the fork legs. Rub it down or remove the lacquer with something first ? Re: Front forks - Mattsplat - 03-03-14 Or use www.mailorderrepairs.co.uk Very reasonably priced to get your forks refurbed/painted/coated. No affiliation to me, just a recommendation ![]() Some of his work can be seen on FB. https://www.facebook.com/MailOrderRepairs Re: Front forks - Sloth - 04-03-14 I bit of autosol and a lot of elbow grease dude . 1200grade wet & dry for raised rusted areas but be gentle and you can get away with filling pits with a very small quantity of araldite, wet & dryed smooth with the leg.
Re: Front forks - darrsi - 04-03-14 I used paint stripper, thinners, wet 'n' dry, then silver wheel spray and lacquer from spray cans........did the job job nicely. Been a while now, still looks fine.
Re: Front forks - stevierst - 04-03-14 If you ride all year round, refurb as the guys above said, then once the paint is fully hardened cover each fork leg in paint protection film. I used just bog standard fablon sticky back plastic from a stationers, it's worked on every bike I've had, and my bikes work hard all year round. Never had to repaint a set of forks since using it! Re: Front forks - Deefer666 - 04-03-14 Buy some 2nd hand fork bottoms and take yer time polishing them to a mirror finish and then rebuild the forks with the new bottoms on |
