rear brake - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: rear brake (/showthread.php?tid=67491) |
rear brake - carlos - 01-03-14 Hi guys first post on here and straight into a question on the back brake have found I need new seals and pistons for the rear caliper do I use pattern parts about 60 quid or oem yamaha parts about 100 any experiencewith pattern parts
Re: rear brake - unfazed - 01-03-14 Go with the OEM stuff, always like to know my brakes will work when I need them. :lol Re: rear brake - Fazer Forever - 01-03-14 Seconded. Easy mod and about ten times better braking. Almost too good if you get carried away. Re: rear brake - carlos - 01-03-14 thank you for the replies the 1000 caliper sounds good but have heard they are hard to find Re: rear brake - carlos - 01-03-14 is the xjr1300 a slot in with no mods do all years fit a fzs600?? anyone done this Re: rear brake - Fazer Forever - 01-03-14 I've fitted a 1000 calliper so if the XJR1300 is the same then it's dead easy. You don't modify the calliper at all, just file a bit off the bracket until the calliper bolts to it properly. It's obvious what to do when you have the bits in your hands. Re: rear brake - noggythenog - 02-03-14 Hey Fizzy Dont suppose next time your at the bike you could measure centre to centre on the torque arm could you. I'd really hate to not use my bling :faz Etched one. :'( Re: rear brake - noggythenog - 02-03-14 (02-03-14, 06:31 PM)Fizzy Pies link Wrote: 240mm between centres nog Cheers geezer! :thumbup Hey fizzy i checked my torque arm...240mm so they're the same size which means i can use my bling one when i fit my thou caliper. For some reason i thought the 600 & thou had different length arms but the thou one must have just looked longer because of its design. Re: rear brake - carlos - 02-03-14 thanks again guys no doubt I will be back soon for more help Re: rear brake - Fazer Forever - 02-03-14 What torque arm is that Fizzy? Looks good, much nicer than standard. Re: rear brake - Fazer Forever - 03-03-14 Cheers. Re: rear brake - noggythenog - 03-03-14 (02-03-14, 06:52 PM)noggythenog link Wrote:[quote author=Fizzy Pies link=topic=11882.msg131128#msg131128 date=1393781481] Cheers geezer! :thumbup [/quote] Hey fizzy i checked my torque arm...240mm so they're the same size which means i can use my bling one when i fit my thou caliper. For some reason i thought the 600 & thou had different length arms but the thou one must have just looked longer because of its design. Re: rear brake - noggythenog - 03-03-14 (03-03-14, 10:28 PM)Fizzy Pies link Wrote:[quote author=noggythenog link=topic=11882.msg131449#msg131449 date=1393881339] The fzs600 and thunerdace arms are both 240mm mate but I'm sure the fzs1000 torque arm is different mate [/quote] Ok geezer.......but the main thing is that you've managed to fit the thou caliper with a 240mm torque arm which is good, maybe if it is a different size then it just means that the caliper is slightly further round on the disc......or maybe the thou has a bigger disc so needs a longer arm to bridge the gap????? Re: rear brake - Chris - 04-03-14 (03-03-14, 10:34 PM)noggythenog link Wrote:[quote author=Fizzy Pies link=topic=11882.msg131461#msg131461 date=1393882139] The fzs600 and thunerdace arms are both 240mm mate but I'm sure the fzs1000 torque arm is different mate [/quote] Ok geezer.......but the main thing is that you've managed to fit the thou caliper with a 240mm torque arm which is good, maybe if it is a different size then it just means that the caliper is slightly further round on the disc......or maybe the thou has a bigger disc so needs a longer arm to bridge the gap????? [/quote] As you said mate, it just means it's further around the disc, slightly further from anchor point on swing arm. Shouldn't make any difference what length it is, as long as there is enough slack in the brake line to reach it. A few cm shouldn't hurt.
Re: rear brake - noggythenog - 04-03-14 Cheers chris Ye im always on about wanting another bike but i cant help myself buying more bits for this one. Suspension & brake lines then I've pretty much replaced everything :eek Re: rear brake - Chris - 04-03-14 (04-03-14, 10:42 AM)noggythenog link Wrote:Suspension & brake lines then I've pretty much replaced everything :eek Apart from the muppet riding it :b :eek Chris Re: rear brake - noggythenog - 04-03-14 (04-03-14, 05:37 PM)Chris link Wrote:[quote author=noggythenog link=topic=11882.msg131556#msg131556 date=1393926178] Apart from the muppet riding it :b :eek Chris [/quote] Oi ya bass!!! :lol Re: rear brake - ChristoT - 04-03-14 (04-03-14, 05:52 PM)noggythenog link Wrote:[quote author=Chris link=topic=11882.msg131631#msg131631 date=1393951068] Apart from the muppet riding it :b :eek Chris [/quote] Oi ya bass!!! :lol [/quote] Sounds right to me!! :lol :lol :lol Re: rear brake - noggythenog - 04-03-14 :b Re: rear brake - Chris - 05-03-14 (04-03-14, 10:28 PM)noggythenog link Wrote::b :rollin |
