Engine Paint - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Engine Paint (/showthread.php?tid=67441) |
Engine Paint - MEM62 - 25-02-14 Its finally happened, the engine paint on my '05 Fazer 1000 has just started to lift. I guess I'll be doing some research to sort out suitable touch-up paint. The areas affected are very small - in fact too small to spray - so I'll need paint that can be applied by brush. Re: Engine Paint - esetest - 26-02-14 RS do touch up paints that are applied with a small brush , the touch up paints are only good for very small areas , if when you rub and remove the loose paint and the area is a lot larger , then the simoniz very high temp spray paint is good . Re: Engine Paint - MEM62 - 26-02-14 Thanks for the heads up. I am looking at two areas each less than the size of my thumbnail. I'll check RS out. Re: Engine Paint - MEM62 - 27-02-14 Paint on it's way from RS. :-) Re: Engine Paint - Andy FZS - 27-02-14 Let us know how well it matches for future reference. Cheers Andy Re: Engine Paint - MEM62 - 28-02-14 Will do. The paint arrived today but I'll probably wait for slightly warmer weather. When it's done I'll post up some before & after photos. Re: Engine Paint - Andy FZS - 28-02-14 Cheers
