replacing fork leg bottom - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: replacing fork leg bottom (/showthread.php?tid=67413) |
replacing fork leg bottom - Kentish - 23-02-14 I am currently doing up a fazer I bought as a project. It has been down the road. I have done most things on it. I want to replace the fork leg bottoms but what I want to know is will are they easy to do? I can remove the oil etc myself. Will I need a fork seal driver to put seals in the new fork leg or is that only if you are putting a seal in and keeping the fork leg whole? Re: replacing fork leg bottom - His Dudeness - 23-02-14 There's a bush on the end of the fork stanchion. You have to force the bush past the oil seal to separate the stanchion from the bottom of the fork. It's a fairly brutal process so you'll probably damage the seal and you'd be wise to replace it. Go for genuine seals. You can use the old seal as the seal drive and knock in the new seal if you're careful Re: replacing fork leg bottom - His Dudeness - 23-02-14 There's a good how to guide http://foc-u.co.uk/index.php/topic,42.0.html Re: replacing fork leg bottom - Dead Eye - 23-02-14 You can make a DIY seal driver using some plastic pipe and a jupilee clip
Re: replacing fork leg bottom - Ruby Racing - 23-02-14 I have a pair of fork bottoms for sale if you're interested. Re: replacing fork leg bottom - Punkstig - 23-02-14 (23-02-14, 07:28 PM)Dead Eye link Wrote: You can make a DIY seal driver using some plastic pipe and a jupilee clipThere's a good 'del boys garage' YouTube clip on change ng fork seals that uses this method! Re: replacing fork leg bottom - Kentish - 23-02-14 (23-02-14, 09:12 PM)Ruby Racing link Wrote: I have a pair of fork bottoms for sale if you're interested. are they new? or dent free? Re: replacing fork leg bottom - Ruby Racing - 24-02-14 They are form a 1998 model with only 12,000 miles on them. The first page of this link will show you why I no longer need them: http://foc-u.co.uk/index.php/topic,10613.0.html Or I also have a pair of complete forks from a the later model with the adjusters on the fork tops. |
