Removing snapped exhaust studs - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Removing snapped exhaust studs (/showthread.php?tid=67388) |
Removing snapped exhaust studs - thunderpantz - 21-02-14 Now, I haven't snapped one... yet. But im looking at changing the down pipes to stainless. The studs on there don't look too pretty at the moment, so just in case, if I snap a stud whats the best way of removal? Re: Removing snapped exhaust studs - darrsi - 21-02-14 Not had to deal with it myself, but why not give yourself a head start and start using regular penetrating spray on them now, you may be thankful for it later. Re: Removing snapped exhaust studs - Buzz - 21-02-14 I'm about to start this myself and have decided to go down the dremel route like Ebme Geek on this thread http://foc-u.co.uk/index.php/topic,6858.msg67155.html#msg67155 Mine are pretty rusty and don't even want to attempt a spanner, I've got a Dremel with a flex cable so better safe than sorry. Re: Removing snapped exhaust studs - Mattsplat - 21-02-14 Buy a stud extractor, it helps! http://www.ebay.co.uk/itm/Stud-Extractor-Remover-Set-6-8-10-12mm-manifold-exhaust-Stud-Extracting-Removal-/251232367180?pt=UK_Hand_Tools_Equipment&hash=item3a7e9db24c But youll still need to soak em WD-40 first. Re: Removing snapped exhaust studs - Dead Eye - 21-02-14 I prefer these; http://www.amazon.co.uk/Laser-4393-Impact-Stud-Extractor/dp/B001DYRDU2/ref=sr_1_1?ie=UTF8&qid=1392986426&sr=8-1&keywords=laser+stud+extractor You can get a really decent grip on the stud that way and its exactly what I used when mine snapped. If they snap flush with the head then its either attempt to drill them out and retap yourself, or engine out and to a machine shop (the latter is what I did and was charged £40 for two studs) Re: Removing snapped exhaust studs - Paul - 21-02-14 I'd warm them up with a blow torch first, the hotter you get 'em the better. Re: Removing snapped exhaust studs - Kentish - 21-02-14 Start spraying them now with plus gas, also when you do take them out it will be the middle two most likely to snap so make sure you get on it flush with a decent socket, let the engine get RED HOT first, then heat the stud with a blow torch until it glows orange. Don't cut corners give yourself the best chance of removing it, you don't want to snap one as it's grief, if you do snap one, Re: Removing snapped exhaust studs - thunderpantz - 23-02-14 Out of interest, what size are the nuts that go on the studs? Re: Removing snapped exhaust studs - wezdavo - 23-02-14 (23-02-14, 07:42 PM)thunderpantz link Wrote: Out of interest, what size are the nuts that go on the studs? M6 Re: Removing snapped exhaust studs - thunderpantz - 23-02-14 (23-02-14, 08:07 PM)wezdavo link Wrote: [quote author=thunderpantz link=topic=11779.msg129283#msg129283 date=1393180926] M6 [/quote] Cheers buddy |
