tyre pressure request - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: tyre pressure request (/showthread.php?tid=67316) |
tyre pressure request - pilgo - 16-02-14 im running Avon storm ultra AV55 front AV56 rear any recommendation as to the tyre pressures i should be using,as 42/43 psi sounds way to hard to me (off the side wall guide) cheers chaps. Re: tyre pressure request - noggythenog - 16-02-14 36 front 42 rear Give it a try 8) Re: tyre pressure request - Andy FZS - 16-02-14 I run 36 / 42 on a 600 fazer. Re: tyre pressure request - Mick-H - 17-02-14 I run 34/39 on the 1000, have done for years and years n years n years. Re: tyre pressure request - Skippernick - 17-02-14 I run 34 front 38 rear. Re: tyre pressure request - Tefer - 17-02-14 36 Front 41 Rear That's what i was told when I was changing to PR3's, is it not tyre dependent though? Re: tyre pressure request - Mattsplat - 17-02-14 There should be a sticker on your chain guard telling you the pressures. Re: tyre pressure request - richfzs - 17-02-14 Never was on mine... Re: tyre pressure request - JZS 600 - 17-02-14 32/36 if under 90Kgs (thanks Mr Yamaha!) Re: tyre pressure request - darrsi - 17-02-14 I'm 100kg but if i went anywhere near 32/36 the bike would go into a wobbly shock! 36/40 is good for me now, i found 42 on the rear a tad too hard. Re: tyre pressure request - Flak - 17-02-14 I'm running 32/36 on my 600 (Storm 2 Ultra) and ride all year round. If you go to the Avon website, they give recommended pressures for each tyre/bike. Re: tyre pressure request - pilgo - 23-02-14 (17-02-14, 09:20 PM)Flak link Wrote: I'm running 32/36 on my 600 (Storm 2 Ultra) and ride all year round. thanks for all the advice,i'll start here as your running the same tyre's on the same bike to me
Re: tyre pressure request - Geordi Sussex - 23-02-14 Done mine yesterday The hayns manual sez front 2.2 bar rear 2.5 Re: tyre pressure request - darrsi - 23-02-14 (23-02-14, 04:44 PM)Geordi Sussex link Wrote: Done mine yesterday Depends on weight load, there's no way i could ride on those pressures. (32/36) Re: tyre pressure request - papercutout - 23-02-14 Mine was around 36, 42 when I got it, but I only weigh about 60kg's, and it was really twitchy when I went over white lines, I'm happily at 33, 37 now. Re: tyre pressure request - stevierst - 23-02-14 I used 34/40psi, and I'm 85kg in my birthday suit :eek. Handled really well for me. I even put about 40-50kg of luggage on the bike with those pressures with no bother. Tried lowering the rear pressure a few times, but it wasn't right for me, a bit too wallowy when cranked over. |
