Which way around does this spring clip go on the rear caliper? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Which way around does this spring clip go on the rear caliper? (/showthread.php?tid=67306) |
Which way around does this spring clip go on the rear caliper? - Fizzy Pies - 15-02-14 or does it even matter? thanks[smg id=1651 type=preview align=center caption="IMAG0187"] Re: Which way around does this spring clip go on the rear caliper? - robby boy - 15-02-14 I would say you are looking at the bottom of the shim in your picture, a quick google shows this, hope it helps ![]() Re: Which way around does this spring clip go on the rear caliper? - dickturpin - 15-02-14 the front ones have arrows to show the direction....doesn't the rear? Re: Which way around does this spring clip go on the rear caliper? - Lez72 - 15-02-14 I have just rebuilt mine and can say as stated above that you are looking at the bottom of the shim in your picture. There is no specific direction unlike the fronts. Regards Re: Which way around does this spring clip go on the rear caliper? - pilgrim - 15-02-14 That's a bit clean isn't it! |
