Gear change lever - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Gear change lever (/showthread.php?tid=66954) |
Gear change lever - fireblake - 16-01-14 I'm experiencing a very stiff gear selection, this has only just happened on my ride home tonight. Does anyone know if there is a bearing on the pivot point that connects to the foot peg? Thanks In advance Mickey Re: Gear change lever - wideload - 16-01-14 Yes there is on the foot hanger, have to take the foot hanger off as there is a Allen key bolt at the back that holds the foot peg and gear lever in place, once off you can lube the bush inside the gear lever. Hope that helps. Re: Gear change lever - fireblake - 17-01-14 Thanks again, a bush rather than a bearing, suits me. I'll have to wait till Tuesday before I can find the time to sort it. Mickey Re: Gear change lever - Tmation - 17-01-14 Make sure both the rose joints are lubed up as well Re: Gear change lever - PaulSmith - 17-01-14 You should get instant relief by spraying with wd40. If it doesn't help, your problem is probaby not there. If it does, you can strip, clean and polish in your own time. Re: Gear change lever - fireblake - 21-01-14 All done. Filled with grit and crud. |
