speedometer sender unit - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: speedometer sender unit (/showthread.php?tid=66507) |
speedometer sender unit - redrat - 02-12-13 Anyone tell me where I can locate this on my gen one thou ? Rgds paul Re: speedometer sender unit - blackcabbie - 02-12-13 back of the engine on gearbox below swing arm Re: speedometer sender unit - AyJay - 02-12-13 It's on the back of the gearbox, an inch or two above the swingarm pivot. If yours has died (mine did), contrary to what a dealer might tell you, you can get to it by without taking the swingarm out. You just need to unbolt the white overflow tank to get access. Mind you, it's still fiddly and a bit of a palaver, but half an hour will sort it. Re: speedometer sender unit - redrat - 02-12-13 cheers for the heads upĀ . |
