floppy shifter - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: floppy shifter (/showthread.php?tid=66463) |
floppy shifter - devilsyam - 27-11-13 Is the gear shift return spring in the same place as gen1 on gen 2 Re: floppy shifter - PaulSmith - 27-11-13 I don't know bout the gen 2, but is this the spring you mean on the gen 1? http://www.yamahamotorcyclespares.co.uk/genuineparts/9023/19/yamaha%20fzs1000%20fazer/shift%20shaft?uid=0 I usually suffer from floppy shifting if the bolt (14) holding the shift arm(10) to the shift shaft (7) is even slightly loose. Might be worth checking first before you do a strip down. Re: floppy shifter - Tmation - 27-11-13 Looks like it might be at the other end http://www.yamahamotorcyclespares.co.uk/genuineparts/9647/20/yamaha%20fz1sa%20fazer/shift%20shaft?uid=0 Part No 1, I have always known them as a detent spring, normally easy to change. Re: floppy shifter - PaulSmith - 28-11-13 Of course the other cause of floppy shifting can be too many pints of Guinness. :o |
