Two or Three brake lines - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Two or Three brake lines (/showthread.php?tid=66386) |
Two or Three brake lines - chr999chr - 19-11-13 Was looking to replace my front brake lines. Whats the difference in the 2 or 3 line standard or race. Is there any benefit fitting one or the other http://www.helperformance.com/motorcycle/yamaha/fzs1000/ Re: Two or Three brake lines - bigbluebear - 19-11-13 I've gone for two, no splitter from the master cylinder. Re: Two or Three brake lines - Falcon 269 - 19-11-13 If you decide to go for a 2-line set, I suggest you look at Venhill because their fittings are adjustable. You might find that this helps with getting the lines to curve correctly down to the calipers. I had a HEL 2-line set for a while but wasn't happy with the routing and reverted to a 3-line set until I fitted R1 forks. Because I needed custom length lines for the R1 front end, I had Venhill make them up for me and the adjustable fittings work nicely. Re: Two or Three brake lines - bigbluebear - 19-11-13 I had mine measured as I have Renthal 773 bars so were custom made to fit from Hel Re: Two or Three brake lines - mickvp - 19-11-13 Ive got a 2 line goodridge setup. no difference bar the splitter is gone AFAIK. Re: Two or Three brake lines - dickturpin - 19-11-13 3 line from hel...which also have adjustable fittings. Re: Two or Three brake lines - nick crisp - 19-11-13 I've had both set-ups in the past, no discernible performance difference, had no problems with routing. Just personal preference really. Re: Two or Three brake lines - Tmation - 20-11-13 I have the 3 line Venhill setup on mine and am very happy with them. I have had Earls and HEL in the past (2 and 3 line set ups), and the Venhills seem nicer (and easier to line up). 2 line front is a requirement for proddy racing (well it used to be), its also cheaper than the 3 line. Just my 2p worth. Re: Two or Three brake lines - JoeRock - 20-11-13 Two lines, it's easier to bleed mainly! Re: Two or Three brake lines - nickodemon - 20-11-13 (20-11-13, 04:11 PM)JoeRock link Wrote: Two lines, it's easier to bleed mainly! +1
Re: Two or Three brake lines - Dave48 - 20-11-13 Just fitted Goodridge 2-line front & (obviously) single rear. My bike is an 03 600 & the original rubber hoses were well past their "best before" date! Have also replaced the brake caliper seals, cleaned & checked everything, applied red rubber grease to outer edges of pistons & also overhauled master cylinder with "Yamaha" kits. Nice new fluid & bled easily. Oh yes, copper grease applied sparingly to back of brake pads and pad pins. Job done-sorted!
