Braided brake hoses - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Braided brake hoses (/showthread.php?tid=66256) |
Braided brake hoses - Gav - 08-11-13 How come those braided hose kids don't put in a hose to go between the master cylinder and T piece.? Only 2 hoses for the front ...T piece to calipers. Re: Braided brake hoses - keithfzs1000 - 08-11-13 :eek :eek :eek :eek they give you the choice either a 3 line ( 1 to t then 2 to calipers) or a 2 piece thats one to each caliper from the m/c Re: Braided brake hoses - Gav - 08-11-13 Ok cheers. I did a search on ebay and looked at the kits on there. Will ava look at HEL :-) Re: Braided brake hoses - Doddsie - 08-11-13 (08-11-13, 10:41 PM)Fizzy Pies link Wrote: Yup, i got the 1 to 2 (standard setup) yep, me too!! Re: Braided brake hoses - Comrade - 08-11-13 Yea i got Good ridge standard , 1 line then the link over to over caliper, works great, was a bastard to bleed compared to others for some reason Re: Braided brake hoses - fazersharp - 08-11-13 Hel, double banjo and two lines for me--done away with the cross bar link over -------------looks messy Re: Braided brake hoses - Doddsie - 08-11-13 (08-11-13, 11:46 PM)fazersharp link Wrote: Hel, double banjo and two lines for me--done away with the cross bar link over -------------looks messy I think the original set up looks neater, one hose coming from the handlebars......... wanna fight???
Re: Braided brake hoses - Gav - 09-11-13 Ahh of course doh what a ding bat I am. The front kits with 2 lines go direct to the m/c then on a double banjo. Takes me a while sorry, especially after a couple of beers Re: Braided brake hoses - bozboz - 09-11-13 (08-11-13, 10:04 PM)Fizzy Pies link Wrote: Which ones Gav? HEL give 25% off on the phone if you mention foc u and do a standard or race setupIs that a fact? Finally the excuse I needed to buy some
Re: Braided brake hoses - Chris - 09-11-13 Yeah, I'll be going for the 2 line kit when I strip and rebuild the front end over winter. I think the 2 line kit is neater, it's also cheaper and easier to bleed as there are less connections and places for air to get trapped Chris Re: Braided brake hoses - Dave48 - 09-11-13 2-line "race" set up front-lighter, fewer connections, easy to bleed, looks good! just need to tie wrap the speedo sensor wire securely when removing splitter & bracket from lower fork yoke Re: Braided brake hoses - Punkstig - 09-11-13 (09-11-13, 10:45 AM)Dave48 link Wrote: 2-line "race" set up front-lighter, fewer connections, easy to bleed, looks good! just need to tie wrap the speedo sensor wire securely when removing splitter & bracket from lower fork yoke What they said, except you can quite happily keep the bracket in place if you do so wish! Re: Braided brake hoses - Skippernick - 09-11-13 (09-11-13, 11:43 AM)Punkstig link Wrote: [quote author=Dave48 link=topic=10643.msg112257#msg112257 date=1383990339] What they said, except you can quite happily keep the bracket in place if you do so wish! [/quote] Which is what i did. Mine was a bastard to bleed and i'm still not convinced its properly bleed, although i did some 70mph emergency stops pretty quickly. Feels like there is more travel than before and the span setting is the same. - - fazersharp - 09-11-13 - |
