FZS600 - No power, won't go faster than 50, engine not smooth - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: FZS600 - No power, won't go faster than 50, engine not smooth (/showthread.php?tid=66148) |
FZS600 - No power, won't go faster than 50, engine not smooth - Torque - 01-11-13 Hiya, My Yamaha was not used for almost 2 weeks, then 2 days ago I've got the parts, replaced some and went for MOT. Everything was fine till today. I've went back from a trip, it has no power and didn't rev on gear higher than 4k, if you open throttle more than 1/4 it's starts to splutter, but it splutters very gently, like it was planned or ECU programmed. You just need to give it less throttle and it does not splutter. It has no power to go on hill higher than few %, also won't go faster than 50mph. I can rev it without gear till 7k rpm, but the vibration and noise is very bad. Since there is no magic there can be 2 issues, fuel or ignition, right? I was trying to remove spark plug cables separately then start engine, but engine runs much worse even If I remove one of them (so I assume that it's not related with just 1 cylinder or 1 faulty spark plugs). What you think I should check next? I know that carb sync and valve clearance it's important, but I don't think that such a power drop would happen after 2 days. I will do it in a next few weeks. I've 4 guesses: a) Water in fuel (have issues with tank drain pipe, which is blocked right now to not leak), but I don't think that it would happen in a 2 days. Motorcycle was running well after 2 weeks of resting, so 2 days are not so much? b) Coil/coils? c) Fuel pump d) Is there ECU or something like that to check? What's your guess and what's the way to check it? I've most of necessary tools and multimeter (to check voltage, resistance etc.) Thanks guys Re: FZS600 - No power, won't go faster than 50, engine not smooth - bozboz - 01-11-13 Sounds very similar to when my fuel pump was packing up. Does the pump prime for longer then usual? Re: FZS600 - No power, won't go faster than 50, engine not smooth - AdieR - 01-11-13 Mileage? Service history / recent work? You say you've replaced parts - what were they (ie, is it possible you've disturbed something during the work you've done?)? You say you pulled the plug leads off - the cylinder you disconnected must have been firing properly (hence why it ran even worse after; if it were faulty, pulling that lead off would make no difference). Have you tried the same with the remaining leads (or, indeed, have you one downpipe cooler than the rest?)? Re: FZS600 - No power, won't go faster than 50, engine not smooth - Paul - 01-11-13 If it were me I'd: 1) Drain the carb float bowls 2) Drain the tank and replace with new fuel 3) Bypass the fuel pump 4) Bypass the fuel filter And see if there was a difference. Assuming there wasn't any difference, I'd clean out the carbs (jets and airways). And if none of that worked, I'd look at the ignition system. Which for me, means staring vacantly at the ECU hoping God would miraculously intervene. Re: FZS600 - No power, won't go faster than 50, engine not smooth - darrsi - 01-11-13 Have you had the tank up/off? Kinked fuel line maybe, and is the fuel tap switched fully on? Re: FZS600 - No power, won't go faster than 50, engine not smooth - Deefer666 - 01-11-13 Sounds like fuel starvation/tank vacuuming, more than likely kinked breather hoses on the underside of the tank, could be fuel pump or filter Re: FZS600 - No power, won't go faster than 50, engine not smooth - Torque - 01-11-13 Thanks guys for help. Quote:Mileage?Mileage 40k+, service history unknown from previous 10k. Quote:You say you've replaced parts - what were they (ie, is it possible you've disturbed something during the work you've done?)?Just suspension and brake system. Shouldn't affect. Quote:You say you pulled the plug leads off - the cylinder you disconnected must have been firing properly (hence why it ran even worse after; if it were faulty, pulling that lead off would make no difference). Have you tried the same with the remaining leads (or, indeed, have you one downpipe cooler than the rest?)?I've tried all cylinders and all of them works fine (because it works much worse after pulling plug leads off) Quote:Have you had the tank up/off?No I hadn't last time, however I will double check it. Assuming guys you point fuel issues, then I will focus on it. It's already dark, but hopefully tomorrow morning if it's not raining I will be able to do something. Thanks you are insane ![]() Re: FZS600 - No power, won't go faster than 50, engine not smooth - Torque - 02-11-13 It's to dark today to do something, but I've ridden her just to "trace" the issue and noticed that you can exceed the 4k RPM by just pushing throttle to the limit. It splutters very badly, but accelerating, after it exceed 6k-7k RPM it's splutters a little or going smooth (depends on mood). Tomorrow I will drain all the fuel, then refill with fresh one. If it won't help then I will bypass fuel pump and filter. If it won't help then I will measure resistance of coils. If it won't help then I will get the carbs off and clean it. If it won't help then... I will read all 40+ pages of FZS 600 splutters topic on the forum
Re: FZS600 - No power, won't go faster than 50, engine not smooth - Paul - 02-11-13 I think it's going to be clean the pilot jets out and the fine drillings (airwways). Which means taking the carbs off I'm afraid. Re: FZS600 - No power, won't go faster than 50, engine not smooth - Fazerider - 02-11-13 Simple things first: catch the fluid you drain out of the carbs so you can see whether there is water present.. if that's not the problem, check the air intake... a rag left there, for example, can do a good job of strangling the power. <edit> My guess the pilot jets are clear, if it starts and runs at low speed the problem sounds more like air or fuel starvation. One check you can do when it's dark is check the plug caps, leads and coils for sparks tracking. Re: FZS600 - No power, won't go faster than 50, engine not smooth - darrsi - 02-11-13 Do a quick TPS check as well, they make the bike run like shite when they break down. Re: FZS600 - No power, won't go faster than 50, engine not smooth - Torque - 02-11-13 Ok I've drained old fuel from tank and carbs. Filter seems to be fine (not blocked), since when I was draining fuel it was going down very fast. When I've replaced with new fuel, I've switched off then on bike for a few times, so pump could build the pressure. (I could hear clicks). Checked coils resistance 2,4ohm (both) and pick up coil resistance 199ohm. When I've ignited bike, it wasn't running smooth for a 2 seconds, then started running fine. Went for a ride and was suprised, because was running much much better. At the beginning it was still spluterring, but after a mile it was running almost fine. I was trying to push it few times very hard and was going as it should. However after few miles problem was almost the same as it was before fuel change. I had no idea, then I've checked TPS and saw 10k RPM (which means that angle is wrong). I was trying to adjust it, but my torx key do not have hole inside so I could not unscrew it .I need to buy this TORX then I will try. Hope that TPS angle it's the only problem. It seems that it's quite random. EDIT: I would like to replace the spark plugs, HT Leads and plug caps, just in case, but it seems that HT Leads are not changeable due to seal in ignition coil, right? Re: FZS600 - No power, won't go faster than 50, engine not smooth - darrsi - 03-11-13 (02-11-13, 08:02 PM)Torque link Wrote: Ok I've drained old fuel from tank and carbs. Yep, leads are part of the coils, just trim about 5mm off the cap end to give it a clean up. http://www.ebay.co.uk/sch/i.html?_odkw=ngk+sp050&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0&_nkw=ngk+SD05F&_sacat=0 Re: FZS600 - No power, won't go faster than 50, engine not smooth - Torque - 03-11-13 [size=1em]Thanks, I've ordered those caps with and set of plugs: NGK CR9E. I've adjusted TPS so it shows 5k RPM also I've measured resistance and it starts from 0,8k and goes up to 4,6k. It seems to be that TPS is fine. After that went for a ride, but bike was running really bad, no power to ride even 30mph. I've went back and was trying to measure coils resistance on HT leads, I've removed plug caps and was measuring resistance between 1,2 cylinder HT lead and 2,4, but it was inifinite. Now I've realised that I should measure propably between 1 and 4 cylinder and 2 and 3 (possibly that's the coils configuration). I will repeat that when got new plugs. [/size] [size=1em]EDIT:[/size] [size=1em]I will wait till spark plugs arrive, h[/size][size=1em]owever my guess now it's ECU or fuel pump.[/size] [size=1em]I don't think that just 2 days when motorcycle was not used, could affect all cylinders. Even if carb jet is blocked possibly only 1 carb and in effet 1 cylinder wouldn't work properly. not all of them.[/size] Re: FZS600 - No power, won't go faster than 50, engine not smooth - Torque - 06-11-13 Measured HT leads on coils, both had 14,6k ohm. Replaced all spark plugs and spark caps. Bypassed fuel pump. Still got the same issue. I will have 2nd ECU tomorrow, but now it's possibly clear what's wrong -> carbs. Do you think that removing them, dismounting, using some carb cleaner from halfords and mounting them again should help? When I remove them is there anything to check, adjust or just clean? Re: FZS600 - No power, won't go faster than 50, engine not smooth - Torque - 07-11-13 Replaced the ECU. Still it's the same, bike starts like a charm, but adding gas make it die. Basically I would worry if bike would have enough power to move. I've detached carbs and dismantled them. All float tanks had some kind of rust at the bottom, but jets looked clear. What you think my problem could be? Can you point me to guide how to proper clean the carburetors please? Re: FZS600 - No power, won't go faster than 50, engine not smooth - CRH - 07-11-13 have you chkd the diaphrams in top of carbs?..ie, for splits or holes etc?....also make sure sliders are moving freely?.... Re: FZS600 - No power, won't go faster than 50, engine not smooth - Fazerider - 08-11-13 This still sounds like fuel over or under supply or air starvation to me. Are the plugs sooting up? Check the fuel levels in the carbs by opening the drain with a length of transparent tube attached in a "U". Have you checked the air intake is clear? Re: FZS600 - No power, won't go faster than 50, engine not smooth - darrsi - 08-11-13 Choke's not stuck in the "on" position is it? Re: FZS600 - No power, won't go faster than 50, engine not smooth - His Dudeness - 08-11-13 Have you checked the air filter? Sounds like classic symptoms of a badger in the airbox. I'd check the airfilter and if its ok clean the carbs. |
