Touch up paint for frame - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Touch up paint for frame (/showthread.php?tid=66045) |
Touch up paint for frame - Captain Haddock - 24-10-13 Has anyone found a good touch up paint for the frame? I have a few rust spots that I'd like to tidy up but assume it's not as easy as bodywork touch up paint, don't want to do a full strip and re-coat. Re: Touch up paint for frame - esetest - 24-10-13 RS paints , spot on colour match but pricy . Re: Touch up paint for frame - bludclot - 25-10-13 rs paint is too soft, doesn't dry without direct heat and costs a fortune. it is also under too much pressure in the can, so all in all it's really quite difficult to achieve good results using it. if you can find a local paint factors to make a good match then that's preferable, unfortunately it's not such an easy colour to match. it's about time yamaha released a paint code for it. Re: Touch up paint for frame - esetest - 25-10-13 Not used the aerosols , just the touch ups , I found the colour match very good , used a hair dryer between coats , and the lacquer after . Re: Touch up paint for frame - nickodemon - 25-10-13 A good tip for touching up paintwork is if you have a spray can shake can then spray a small quantity into the cap and use a small touch up brush. Halfords can supply you a fine touch up brush usually free of charge.
