Please help to diagnose a noise? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Please help to diagnose a noise? (/showthread.php?tid=66007) Pages:
Please help to diagnose a noise? - notoriusb.e.n - 22-10-13 Hi folks. I have an odd noise on my 03 fazer 600 - its like a bit of a rattly noise that increases in severity as you accelerate, then goes away when you get up to certain revs. Either that or its drowned out by the Beowulf. I don't think its the cam chain, as I've had that before on a superdream and that rattled way worse than this, and also at a standstill. was proper rough. I've checked the drive chain tension and it seems to be OK to me, got about an inch of play in total up and down? I'm going to try pushing the bike without the engine running see if it still makes the noise - which would hopefully indicate whether its the engine or something else. admittedly I hadn't thought of that yet. only other thing I can think of is the rear hugger might be a bit loose and rubbing against the rear tyre, but I would have seen signs of damage/wear to the hugger i'd have thought. I appreciate the awkwardness of this request - as its difficult to describe a noise over the internet, and as it doesn't do it unless I'm riding I can't "record" it as such. but any ideas or at least reassurance that its likely to be something minor would be nice. I should note that the bike still runs and rides perfectly fine with no noticeable adverse effects. Re: Please help to diagnose a noise? - Fazerider - 22-10-13 Even a correctly tensioned dive chain will be noisy if it's worn. Try pulling on the chain at the 3 o'clock position on the rear sprocket, if it's stretched enough to come away from the sprocket by a couple of millimetres it's probably the cause of the noise. Re: Please help to diagnose a noise? - darrsi - 22-10-13 Another thing you can eliminate, put the bike on the centre stand and spin the front wheel, i've had brake pads chattering before when they slightly catch on the discs, which is either a worn caliper or even just ill fitting pads. Bit difficult to guess to be honest. Re: Please help to diagnose a noise? - notoriusb.e.n - 22-10-13 Done a little more home diagnosis. it doesn't make any noises being pushed around. I've eliminated the hugger as even wiggling it about (which you can't really do without abnormal force anyway) won't foul the rear tyre, so its not that. so its looking like engine related possibly. Been sat on it revving and there is a tickety tappety chuggety noise which appears to come from the top left hand side of the engine and increases on revs. but then that could be normal. I will try the chain pull anyway, just in case. I'd be quite relieved if its just needing new C+S, I've been expecting them to want doing at some point. but as its not done it while being pushed I don't know. but then I'm not pushing with the force of the engine either. Re: Please help to diagnose a noise? - darrsi - 22-10-13 You're describing the cam chain, like a sewing machine noise? Have a look on YouTube and see if the sound is similar? https://www.youtube.com/results?search_query=fzs+600+cam+chain+noise&oq=fzs+600+cam+chain+noise&gs_l=youtube.3...955.7512.0.8321.23.23.0.0.0.0.207.1775.19j3j1.23.0...0.0...1ac.1.11.youtube.SJMRSl_0f_I Re: Please help to diagnose a noise? - notoriusb.e.n - 22-10-13 Well its nowhere near as bad as those noises no. and its not quite sewing machine, more tractor. I will try and record it but as it mainly does it when riding rather than at a standstill its going to be awkward (don't have a cam other than phone camera) Re: Please help to diagnose a noise? - darrsi - 22-10-13 (22-10-13, 09:30 PM)notoriusb.e.n link Wrote: Well its nowhere near as bad as those noises no. and its not quite sewing machine, more tractor. How can a tractor not be as bad as a sewing machine? :lol Re: Please help to diagnose a noise? - Doddsie - 22-10-13 How can a tractor not be as bad as a sewing machine? :lol :rollin :rollin :rollin Re: Please help to diagnose a noise? - CRH - 22-10-13 (22-10-13, 10:47 PM)Doddsie link Wrote: How can a tractor not be as bad as a sewing machine? :lol......stop it doddsie?...you got me in....STITCHES here" :lol :lol :lol :lol :lol :lol Re: Please help to diagnose a noise? - noggythenog - 22-10-13 I dont know much really but a common thing with Fazers is having the chain too tight. Also...,have you actually inspected the front sprocket....it could be shot to shit & the chain slipping. Thrice....have you checked if your front sprocket nut is still attached....there's a known fault..if you havent checked it then do not ride again until you do & get back to us. Re: Please help to diagnose a noise? - darrsi - 23-10-13 The thing about chain issues is that you "should" feel problems through your left foot rest. I must confess i'm no closer to guessing what this noise is or where it's coming from? :look Re: Please help to diagnose a noise? - midden - 23-10-13 Can you record sound with engine going through rev range with bike on stand. Re: Please help to diagnose a noise? - darrsi - 23-10-13 (23-10-13, 08:21 AM)midden link Wrote: Can you record sound with engine going through rev range with bike on stand.Have to be very careful doing this as the chain will slap and the bike becomes a bit unsafe. Re: Please help to diagnose a noise? - midden - 23-10-13 I mean steady throttle control with gradual rev increase as opposed to blip blip wee
Re: Please help to diagnose a noise? - His Dudeness - 23-10-13 Try covering the end of the exhaust with a rag as you're reving the engine to quieten the can. Should help you hear if it's a problem in the engine Re: Please help to diagnose a noise? - notoriusb.e.n - 23-10-13 by tractor i mean its a more gruff rumbly chugging noise than it is a sewing machine noise. it might be that the cam chain could be just on the way out, and its going to get more rattly if left unchecked. Thanks for the rag tip. the exhaust is pretty loud so it does make determining location of noise a little awkward. tried it on the centre stand in gear and yep, that chain does slap a bit. Don't feel anything through my feet unfortunately so nothing there. I will try and record it tomorrow and get it uploaded. i've done the front sprocket nut upgrade so that certainly shouldn't be the cause. good point about the sprocket being worn though. haven't checked that. will do. also tried pulling the chain backwards off the rear sprocket and no budge at all there. Re: Please help to diagnose a noise? - darrsi - 23-10-13 "...gruff rumbly chugging noise ..." That sounds like me down the pub on a Saturday night. :b :lol My money's still on the camchain. What is the mileage by the way? Re: Please help to diagnose a noise? - notoriusb.e.n - 24-10-13 14K. Which is why I'd be surprised if it were anything engine related. surely its not had enough use for anything to go there. have only done 2K myself and its definitely not had the hardest of lives - its pretty much mint still cosmetically. Re: Please help to diagnose a noise? - darrsi - 24-10-13 (24-10-13, 01:29 PM)notoriusb.e.n link Wrote: 14K. Which is why I'd be surprised if it were anything engine related. surely its not had enough use for anything to go there. have only done 2K myself and its definitely not had the hardest of lives - its pretty much mint still cosmetically. Okay, that's more than likely ruled the cam chain out then. We're gonna need to hear it to be able to guess any further i think! Re: Please help to diagnose a noise? - notoriusb.e.n - 24-10-13 Have recorded it going to upload to youtube when I get home tonight. Afraid its only the tickover noise, as I haven't a proper cam to record whilst riding. |
