Ignition lock question - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Ignition lock question (/showthread.php?tid=65948) |
Ignition lock question - solorider - 16-10-13 As my barrel is getting very worn after 72k miles, the key can be pulled out with the ignition on, I know the 2003 on have a different switch, so I need to know can the switch part be swapped over? The reason I need to know is there are no 2001-2002 lock sets for sale but a few 2003 on lock seta. Re: Ignition lock question - stevierst - 16-10-13 Mine did that for a couple of years, I just lived with it rather than replacing all the barrels, too much hassle if you ask me. Re: Ignition lock question - Lez72 - 16-10-13 As far as I am aware there should be no difference between the 2002 and 2003 lock sets. All I can tell you from recent experience when looking for a genuine 'Key blank' for my 2002 Gen 1 was that Yamaha did not list a 'Key blank' for the 2001 or 2002 models but they did list one for the 2003 models. I took the risk and bought one and it turns out its the correct item so this could well be the case with the lock sets aswell. Re: Ignition lock question - AdieR - 16-10-13 Not familiar with that bike, have you got a factory fitted immobiliser on yours? Re: Ignition lock question - AyJay - 16-10-13 I noticed the same on mine and now I put the key back in my pocket after switching on. One really good bump and I'm sure it could jump out, it's so loose. Re: Ignition lock question - ghostbiker - 17-10-13 Not a straight swap. The later ones have a different plug set up. Mostly down to the later having a different light switch set up. There may be a way to cut and join but not able to plug and play. Brought 3 sets in all before I worked out the difference. Got one from a breaker in the end but did cost me over the odds at 80 quid for a lock set. Re: Ignition lock question - daisyjohn - 12-11-13 The switch mechanism can be removed from the bottom of the lock unit and be either cleaned or replaced. |
